Author Topic: Stripping paint off interior panels  (Read 7318 times)
Offline mikeporp
« on: August 28, 2014 - 08:15:28 AM »
I have a 70 challenger convertible. when I bought it the interior panels were spray painted black they are originally white. The paint is slightly peeling off does anyone know a good way of removing the black paint without destroying the panel. I want to restore them back to the white panels. Thanks. Mike
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Stripping paint off interior panels
« Reply #1 on: August 28, 2014 - 08:51:11 AM »
I will be doing this soon too.   :popcorn:
Offline anlauto
« Reply #2 on: August 28, 2014 - 09:17:53 AM »
Pressure washer
Offline CudamanTom
« Reply #3 on: August 28, 2014 - 09:43:30 AM »
I've got some panels of the same situation.
So pressure washer? that's it?
No spray on paint lifter stuff?
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #4 on: August 28, 2014 - 10:00:04 AM »
I responded your the other post where you asked this question.  Personally, I'd try oven cleaner.  Test it on the back of the panels first just to make sure it doesn't do something weird to the plastic.  I used oven cleaner to strip the paint off of my Dart's plastic dash bezels.  The paint just wiped right off after soaking about 20 minutes.
Offline mikeporp
« Reply #5 on: August 28, 2014 - 10:35:59 AM »
 Ok thanks for the tips I was also told brake fluid
« Reply #6 on: August 28, 2014 - 10:49:36 AM »
That is also an option.  I've hear of brake fluid doing weird things to the plastic too though.  The oven cleaner would work faster then brake fluid as long as the plastic isn't affected.  The plastic on my dash bezels is a different plastic then the interior panels.  That's why you need to try some on the back side first.
Offline anlauto
« Reply #7 on: August 28, 2014 - 11:59:24 AM »
That's where I would start :2cents:
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #8 on: August 28, 2014 - 01:45:17 PM »
I used Easy-Off oven cleaner to remove old paint from some of my interior panels.  It worked very well with multiple applications, and scrubbing with a soft bristle brush.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline challengerx
« Reply #9 on: August 28, 2014 - 06:42:42 PM »
I used goof off, make sure you test it first though whatever you use
Offline PlumCrazyRTSE
« Reply #10 on: August 28, 2014 - 07:08:34 PM »
 :iagree: Yep, Easy-Off works well and doesn't seem to melt the panels like a lot of other things will.  Purple Power is another product that contains lye, so it should also work.  You should test whatever your planning to use on the a small section of a panel back to convince yourself that it's safe.
« Last Edit: August 28, 2014 - 07:11:03 PM by PlumCrazyRTSE »
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FC7 Plum Crazy Purple
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FE5 Bright Red
Offline CudamanTom
« Reply #11 on: August 28, 2014 - 08:44:24 PM »
All these inputs and advice is great!!!  :2thumbs:
Offline plumcrazzy
« Reply #12 on: August 28, 2014 - 08:56:39 PM »
Did mine with laquer thinner. Worked great with no damage. Use in a well ventilated with rubber gloves and maybe eye protection. Laquer thinner is like mothers spit---it will clean anything!!! :burnout:
Offline mikeporp
« Reply #13 on: August 28, 2014 - 10:23:15 PM »
Thanks so much to all for the tips .are all good ideas. i will start with the power washer and move on from there. Much appreciated :D
Offline Jesus H Chrysler
« Reply #14 on: August 28, 2014 - 11:24:34 PM »
:iagree: Purple Power is another product that contains lye, so it should also work.  You should test whatever your planning to use on the a small section of a panel back to convince yourself that it's safe.
 :iagree:  My white panels weren't painted, but they had 40 years of smoke and what all else coating them to a light brown.  I used Purple Power and a soft brush and they all came out nice.  Took some time, but was worth it.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
