Can someone verify these casting numbers
Author Topic: Can someone verify these casting numbers  (Read 1490 times)
Offline KZ
« on: August 29, 2014 - 01:08:31 PM »
Looking for 1970 440 Six Pack Dodge Challenger correct casting numbers for original exhaust manifolds.  Are these the correct numbers? Left: 2951865 and Right:2899879.
thanks
Offline Rich G
Re: Can someone verify these casting numbers
« Reply #1 on: August 29, 2014 - 01:34:05 PM »
In the restoration guide those are the right numbers for the 440 but they don't list anything separate for 440-6 so I would assume they were the same. Not that that book is 100% correct???
Offline KZ
« Reply #2 on: August 29, 2014 - 01:41:39 PM »
thanks,
Offline anlauto
« Reply #3 on: August 29, 2014 - 06:55:14 PM »
Yes, they are correct :2cents:
Offline KZ
« Reply #4 on: September 04, 2014 - 08:31:27 AM »
I found a pair of exhaust manifolds online but the left cast number is 2951865-2
What does the –2 mean?
Would this still be considered numbers correct for a 1970 Dodge Challenger 440-6?
« Reply #5 on: September 04, 2014 - 06:50:55 PM »
Likely it means it's the 2nd cast revision.
The casting cases halves eventually wear out. Then they make new one's and that is why it has a  -2.
