Author Topic: Tremec 5 spd or Gear Vendors OD  (Read 4915 times)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Tremec 5 spd or Gear Vendors OD
« Reply #15 on: August 30, 2014 - 02:04:22 PM »
Look for the GVOD part number for your application on TTI web site.
http://www.ttiexhaust.com/Category-ClassicExhaust/MFDback.htm -  for manifolds back
http://www.ttiexhaust.com/Category-ClassicExhaust/HDRback.htm -  for headers back
It looks like the H is wider, I thought it would have been further towards the rear. $240 for just the new H-pipe section.  :pullinghair:
I may have to just fab a piece of pipe in or air hammer the floors.
« Reply #16 on: August 30, 2014 - 02:43:58 PM »
Wow, maybe I should get into the exhaust business. Three systems a week would replace my current paycheck.
Offline twalker
« Reply #17 on: August 30, 2014 - 05:33:14 PM »
Today American Powertrain told me 8 weeks for a TKO600 kit.
Hahaha, we know better...
Offline anlauto
« Reply #18 on: August 30, 2014 - 06:53:49 PM »
How did your install go ? Not exactly a "bolt in kit " eh ?
Offline twalker
« Reply #19 on: August 30, 2014 - 07:20:17 PM »
Well it went together fine after they warranty'd the unit - bent shift rod.  But I've only done a mockup so far as I was converting from auto to manual - so modifying the tunnel for both the shifter and fitting the tremec.  I'm onto blocking and body work and hoping to paint in a month so reassembly can happen over the winter and spring .... Big job, I know you know that!
