74 360 cuda auto trans not original motor but it is a 360. It runs and drives but needs brake work. It will need trunk pan,drop offs, lower quarters,front drivers side floor pan, comes with all the new sheet metal to fix these areas but I do not have the front floor pan. Frame rail has one spot at the very rear of the drivers side, not a hole but it looks puffy,rest of the frames look good. The car came with a lot of options, 2 fender tags which are decoded in the vin tag section of this forum, also have 3 build sheets for it 1 is very hard to read though. Very complete car. The car is located in central Illinois, 9500.00 for car and sheetmetal.
