Author Topic: 74BlueFish starting reassembly  (Read 7023 times)
Offline 74BlueFish
Re: 74BlueFish starting reassembly
« Reply #15 on: August 31, 2015 - 04:29:51 PM »
Will do.   Car is not driving yet.  Get the exhaust system  and driveshaft this week.  then I will start the tuning of the megasquirt in a few weeks.
Dan
Dan
Offline 74BlueFish
« Reply #16 on: November 26, 2015 - 09:49:56 AM »
Still plugging away.   Exhaust and drive shaft are in Brakes almost done.
Made a cold air intake for it.
Cut and glued stryofoam
Cover it in fiberglass
Top layer in carbon to look cool :bigsmile:
In the car
In Car with tube to intake and filter
Complete with top cover
It gets it's air from the opening to access the upper A arm.
Dan
Offline YellowThumper
  • I left the snow for this?
« Reply #17 on: December 02, 2015 - 02:19:25 PM »
Dan
Good luck with the Megasquirt setup. Have my MS3 now and have started the long slow wiring process.
Are you new to setting it up or seasoned?
Interesting idea on the air box. Those openings have been on my mental design radar for air inlets to the turbos.
Offline 70chall440
« Reply #18 on: December 02, 2015 - 02:43:29 PM »
Seems like a pretty small hole to draw all your air in from, not to mention being on the side in a wheel well. Sure it will run ok, just not real conducive to performance I wouldn't think.
Current Mopar
Past Mopars
« Reply #19 on: December 02, 2015 - 04:07:07 PM »
X2 on that thought. One of the reasons I have not been able to talk myself into it.
Normal cruise would be OK but top end rpm. ???
Another option in my thoughts is to utilize the hood openings. They could be discreetly opened up a bit and then underside of hood sealed off to effectively make a plenum.
No bash just some thoughts...
Carry on.
Offline 70chall440
« Reply #20 on: December 02, 2015 - 04:19:12 PM »
Just food for thought, if that box shown in the picture extended to the radiator support and there was a large hole there you would better for the high end. I really like the box and the craftsmanship displayed building it.
Current Mopar
Past Mopars
Offline 74BlueFish
« Reply #21 on: December 04, 2015 - 11:44:24 AM »
Engine has started on megasquirt but I haven't driven or tuned it yet,  so I'm just a beginner.
Thanks for the advice on the size of the opening.  I agree it looks a little small, I might open it up or make a hole near the headlights.   I'm leaning towards the hole that is already there for the A arm access.
Not worried about it been in the wheel well, still cold air.    Not worried about ram air.
I have ram air on my plane, direct straight into the throttle body, no air filter  and I get +1.75 inches of mercury effect at 200 mph.  So on a car it won't make a difference.
Dan
Offline rUNCHARGER
« Reply #22 on: December 04, 2015 - 11:51:40 AM »
That opening is probably as big as both the openings on a dual snorkle aircleaner, so it would be no worse than stock.
Sheldon
Offline 74BlueFish
« Reply #23 on: December 04, 2015 - 12:02:26 PM »
Well, that's good to here,   I'm going to try it that size and if it runs out of breath I'll open it up.
Dan
