Author Topic: fuel sending unit issues  (Read 3269 times)
Offline aris_unlimited
  • Project in full swing
Re: fuel sending unit issues
« Reply #15 on: September 21, 2014 - 10:45:15 AM »
Got my new sending unit installed.  I did have to change the fuel line to 3/8 rubber hose where the 2 steel lines connect but that wasn't a big deal. The original ground strap wasn't long enough due to a shorter fuel outlet line on the sending unit, so I had to make one that would work out of wire and hose clamps lol, but it does work now! Fuel gauge reads accurately as far as I can tell so far. And now I can use more of my gas, because I realized after (supposedly) running my car empty, I still had a 1/4 tank of gas because the old sending unit didn't allow the pickup line to go down far enough in the tank, the new one goes down much farther. The only other installation issue I had was installing the electrical connector (female) onto the fuel sending unit (male). The female end was loose, but I solved that by lightly tapping the female end on with a hammer, and now it fits fine. So while it was not as easy of an install as it could have been (as in everything went perfect) it wasn't to bad and I am really happy to have a working fuel gauge again. Assuming this unit lasts as long as the original did I will be really pleased with this piece lol. 10/10!
Cuda is gone :(
74 satellite, daily driver/project now
Offline tman
« Reply #16 on: September 21, 2014 - 12:03:51 PM »
Makes a difference getting a quality sending unit.  Good to hear.
Offline ec_co
« Reply #17 on: September 22, 2014 - 08:45:27 PM »
Keep your original ones. Soak them in EvapoRust and reinstall them. My guess is that most will work again.
great idea! I have an order in with Dixie as well and waiting for the actual production to take place, but this should be a good option as well and i'll have a spare (original + the reman)
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
