Author Topic: Rt se with no radio??  (Read 3636 times)
Offline Yellow Submarine
« on: September 02, 2014 - 06:00:44 PM »
My 70 RT SE did not come to me with any radio. It does have a radio delete panel. The front fenders were replaced so not sure about it coming with an antennae or not. Rear shelf has holes chopped out for two aftermarket speakers. It looks like a blank plate below the center dash speaker grill. It does not look like a speaker cone. Finally the build sheet has nothing marked off under radio or speakers.
Doesn't this seem kind of strange given that the car is an SE and not a stripper?
John :swear:
70' RT SE 383 Challenger
Factory Five MkIII Roadster (Cobra)
66' Mustang FB (GT 350 Clone)
70' Kawasaki 500 Mach III (H1)
Offline EB3-GranCoupe
  • BP23 U0B
Re: Rt se with no radio??
« Reply #1 on: September 02, 2014 - 06:14:32 PM »
Do you have the data plate codes handy? post them, and lets see if you have an R code (R11, R22, R35) or not.  if you don't, then it is a Radio Delete car.  The original right front fender would not have the antenna hole, nor would the inner right cowl/panel where the antenna wire would have gone through.
« Reply #2 on: September 02, 2014 - 06:31:17 PM »
There is nothing starting with an R on the fender tag. I'm not sure where the antennae cable enters the cabin. There is a cable laying on the floor that is routed through the panel behind the kick panel on pass side. No antennae or radio gear.
John
  • BP23 U0B
« Reply #3 on: September 02, 2014 - 07:16:38 PM »
Do you have a pic of your data plate? Or can you post the codes exactly as they appear, line by line (you don't have to include the VIN if you don't want; 6x's will mark the spot!).  there are some A codes that include the radio, however I have never seen one that didn't also have the R code listed as well.  An SE without a radio would be quite unusual, but not out of the question.
« Reply #4 on: September 02, 2014 - 07:49:03 PM »
Here's the tag photo.
« Reply #5 on: September 02, 2014 - 07:49:46 PM »
Here's the dash photo.
  • BP23 U0B
« Reply #6 on: September 02, 2014 - 08:08:20 PM »
Well, I am no expert by any means, but from what little I know, if the data plate did not have any of the Radio codes (R11, R22, R35) then it didn't come with a radio.  The other option was the Accessory Group A04 that included a radio, and of all the plates I have seen with A04, the R code also shows up.  you have neither.  My understanding is the data plate controls what steel panels/parts the chassis is built with.  Each code that shows up specifies a particular body panel, (i.e. H51 would indicate a firewall panel with A/C mounting and placement holes; lack of H51 would be a standard firewall), C16 would indicate that center console brackets on the floor pan were installed; lack thereof would indicate no brackets and  no console, etc.).  So no R code would indicate to me no Radio was installed, and the appropriate panel without the needed holes for the antenna were used (fender and inner cowl support).
I have never seen an E-body radio delete panel, but if what you have has the Chrysler part number and logo, then I am sure it is worth its weight in gold!
Other than that, you have a very nice 383 4bbl automatic, Lemon Twist with black hood and side stripe, Black Leather Interior, with A/C, bucket seats, and overhead console (an SE exclusive) R/T-SE.   :cheers:
« Last Edit: September 02, 2014 - 08:10:41 PM by EB3-GranCoupe »
Offline anlauto
« Reply #7 on: September 02, 2014 - 08:33:19 PM »
Not that uncommon, people just forgot to order a radio, or chose not to... :2cents:
« Reply #8 on: September 02, 2014 - 11:06:19 PM »
My R/T SE was also a radio delete , no antenna hole , no R code , & unfortunately no delete plate either
« Reply #9 on: September 03, 2014 - 12:43:36 AM »
Not that uncommon,  or chose not to... :2cents:
Because they weren't into music.
They lived in areas that didn't have good reception.
Or they were just trying to save money.
AM radio was the dominamt listening then.
« Reply #10 on: September 03, 2014 - 01:53:26 AM »
 When my car was built It was the summer between 9-10 grade and I lived in the SF bay area. All we listened to was am radio. Favorite stations were KFRC AND KYA.
There were a bunch of nice Mopars on the base then. OK getting a little off track here.
John :jumping:
« Reply #11 on: September 03, 2014 - 02:38:57 AM »
John :jumping:
Those stations bring back old memories.  ::)
« Reply #12 on: September 03, 2014 - 02:47:34 AM »
John :jumping:
KLIV AM 1590 was the station that turned me onto Rock n roll.   :ylsuper:
Offline cordodge
« Reply #13 on: September 03, 2014 - 07:35:00 AM »
I was lucky enough that my car still had the delete plate and the flat speaker plate that screwed in place of the speaker, I would imagine they would be hard to find.  bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline anlauto
« Reply #14 on: September 03, 2014 - 09:08:36 AM »
The "WORLD FAMOUS BARRELCUDA" had a three speaker dash, dual rear speakers (with RWDefrost) and a console mounted cassette deck all connected to an AM radio.
When I asked the Newfee why he only ordered an AM and not an AM/FM.....his answer was pretty quick.....there was NO FM stations on the Island at that time.... :dupe:
The guy played in a rock band at the time so he really wanted his tunes ! :smokin:
