Author Topic: 71 e body: Adjusting front end height  (Read 1401 times)
Offline DocMel
« on: September 04, 2014 - 09:39:34 AM »
I understand the front end ride height can be adjusted to a point over the recommended stock setting?
 Id like my front fenders to ride a little higher over the front tires.  Even an inch or so would make me happy
Which way to I turn the adjusters?
Also, if I can raise an inch or so, is it recommended that I get the front end alignment done again?
Re: 71 e body: Adjusting front end height
« Reply #1 on: September 04, 2014 - 09:52:02 AM »
You need to tighten the adjuster bolt / clockwise to raise the car . Make sure the weight is off the suspension when you do this go 5-6 full turns drive the car & see if it settles at the height you want . Resetting the alignment is a must as the toe in will change with adjusted height
Offline DocMel
« Reply #2 on: September 04, 2014 - 10:26:27 AM »
Super and great timing Chrycho.   I have the car on my lift now and was waiting for response.  And simple instructions as well.   Will try, if it works Ill get the alignment done as well
« Reply #3 on: September 04, 2014 - 10:54:22 AM »
the camber will change slightly but the toe in is the one that really changes , if you have 2 people you can reset the toe in with a tape measure across the front & rear of the tires using the same place in the tread front & rear , you only want 1/16" - 1/8" of toe in .
Offline anlauto
« Reply #4 on: September 04, 2014 - 12:28:01 PM »
You should loosen the big nuts on front of the lower control arms before adjusting the height. :2cents:
Offline DocMel
« Reply #5 on: September 04, 2014 - 12:38:01 PM »
I hadn't thought of that, will do
