Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
Anyone build their own exhaust?
« previous
next »
Print
Pages: [
1
Author
Topic: Anyone build their own exhaust? (Read 3897 times)
RCCDrew
Sr. Member
on:
September 05, 2014 - 08:32:52 PM »
I am wanting to build a new exhaust system for my cuda as the one that was built locally for my car is probably the worst POS possible. It hits the chassis and the rear axle, and has some cheap glasspacks that are probably the pinch point of the system.
Anyway, has anyone built their own? Any tips or tricks to offer?
Logged
crash340
Sr. Member
Re: Anyone build their own exhaust?
Reply #1 on:
September 05, 2014 - 08:44:59 PM »
I bought a Magnaflow then like others cut and shut to suit, particularly from the mufflers back up and over the diff etc, I also mounted some 6", magnaflows either side of the gas tank
Logged
Greg
73 Cuda
Brisbane, Australia
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #2 on:
September 05, 2014 - 08:57:23 PM »
Put in a 2.5" Pypes stainless system & headers, doesn't come with head pipes, I had to fab collector to exhaust connection otherwise pretty straightforward.
To make the connection I needed 180-bend, a chop saw, welder and lots of patience
http://www.cuda-challenger.com/cc/index.php?topic=31954.msg642011#msg642011
Last Edit: September 05, 2014 - 09:12:16 PM by Bullitt-
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
brads70
C-C.com Expert
Reply #3 on:
September 05, 2014 - 09:15:18 PM »
I also used the stainless magnaflow system. Had to buy a mandrel bend and make one pipe fit my header but overall and happy with it. I've built a few exhaust systems from scratch, use mandrel bends, it's not hard to do.
Logged
RCCDrew
Sr. Member
Reply #4 on:
September 06, 2014 - 01:34:59 AM »
What kind of hangers do you like to use?
Logged
brads70
C-C.com Expert
Reply #5 on:
September 06, 2014 - 04:45:10 AM »
Quote from: RCCDrew on September 06, 2014 - 01:34:59 AM
Magnaflow supplied them too.
Logged
crash340
Sr. Member
Reply #6 on:
September 06, 2014 - 05:44:40 AM »
I used the magnaflow supplied muffler hangers and the factory Cuda rear hangers with an adapted pipe clamp that also is adjustable so as the tips can be located perfectly in the valance cut outs
Logged
Greg
73 Cuda
Brisbane, Australia
Bullitt-
Permanent Resident
Reply #7 on:
September 06, 2014 - 05:56:35 AM »
Didn't use the supplied hangers as they would require drilling new holes so I picked up a couple of Walker brand hangers at Autozone that would adapt to the OE positions for over the axle & went with reproduction OE for the tail pipe.
Logged
Huntsville, AL
crash340
Sr. Member
Reply #8 on:
September 06, 2014 - 06:19:30 AM »
I would have liked to do that but my car only had a hanger on the left hand side so I had to drill in anycase on the right hand side, only two holes per side, easy enough to plug should I have to.
Logged
Greg
73 Cuda
Brisbane, Australia
Sp33dyF1sh
Jr. Member
Reply #9 on:
September 06, 2014 - 08:47:50 AM »
Speaking of exhaust, a stock exhaust from a 2010 charger rt wouldn't be an upgrade to my 2011 chally se would it....
Sent from my iPad using Tapatalk
Logged
RCCDrew
Sr. Member
Reply #10 on:
September 08, 2014 - 10:01:25 PM »
I've been thinking about rigid mounting the exhaust to the car with flex pipe between the headers and the start of the exhaust pipe. Any thoughts on this?
Logged
aris_unlimited
Project in full swing
Full Member
Reply #11 on:
September 08, 2014 - 10:04:53 PM »
I've built them before and I think the most important part is to get under the car and measure everything out and draw up the way you want the system so you can find the proper pieces needed to build it.
Logged
Cuda is gone
74 satellite, daily driver/project now
Bullitt-
Permanent Resident
Reply #12 on:
September 09, 2014 - 12:41:04 AM »
There's a couple of different types of flex exhaust pipe, the lightweight stuff is junk, the better stainless braid is very expensive and I wasn't sure it would have been flexible enough to do what I needed, I did look at that option.
Logged
Huntsville, AL
dave73chally
Sr. Member
Reply #13 on:
September 11, 2014 - 11:01:48 PM »
Anyone ever mockup their exhaust with pvc pipe for cheap reassurance? I've seen custom headers done like this before, crossed my mind when I go down this route..
Logged
73 Challenger
RCCDrew
Sr. Member
Reply #14 on:
September 12, 2014 - 05:53:44 PM »
Interesting you say that. Check this out.
http://www.stainlessheaders.com/custom_exhaust
They talk about PVC mockup. I think I'm gonna mock up PVC tailpipes.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
