Author Topic: Just keeps wanting more fuel but why?  (Read 5003 times)
Re: Just keeps wanting more fuel but why?
« Reply #15 on: September 07, 2014 - 08:03:25 PM »
If covering the carbs with your hands brings up the RPM it is obviously lean so I doubt you will fix it with the ign system
Offline 1 Wild R/T
« Reply #16 on: September 07, 2014 - 08:30:58 PM »
The point of looking at the ignition isn't to correct the obviously lean mixture it's to correct the dieing when he attempts to bring the car down to idle...  Actually a common issue with the M/P distributors when you run a cam that likes to idle above 800ish rpm's...
Might add if the springs that raise the needles were an issue it would be fat at idle, not lean...
« Reply #17 on: September 07, 2014 - 08:51:31 PM »
it may come down to drilling holes in the throttle plates so you can get the throttle plates closed down so the idle transfer slots are covered properly & idle mix becomes responsive again . Not sure you want to do this to rare factory carbs though . you might want to run it with cheaper carbs that cannot be seen under the shaker hood anyway . Have you swapped springs under the metering rods to make sure they are staying down at idle also
I really don't want to drill out the throttle plates.
Earlier AFB's are smaller top diameters than the new Carter replacements.
I could do that, but then I would have to also buy another air cleaner baseplate from shakerhood.com
They are expensive. Like $750 bucks.
« Reply #18 on: September 07, 2014 - 08:59:37 PM »
 I used to throw out the eddy carbs , no use for them , if you could get a couple just to try them at least it would prove the theory , maybe the tops would swap ???
« Reply #19 on: September 07, 2014 - 09:30:30 PM »
We swapped the bottom half of a later Carter putting top half of my OEM's with idle adjustments on the front carb a few months ago. Before I replaced the intake gaskets just last week.
No noticable difference in idle quality then.
Offline 1 Wild R/T
« Reply #20 on: September 07, 2014 - 10:11:30 PM »
You can get a little extra air in to the engine without drilling the throttle plates by cracking the secondaries open slightly so you can close the primaries & possibly gain some idle mixture adjustability by exposing the transfer slots...
Without looking at your carbs I'm not gonna suggest how to crack the secondaries but since initially it's just a test I'm sure you could get creative..
Offline cudabob496
« Reply #21 on: September 07, 2014 - 11:45:43 PM »
the new Holley HPs have an adjustbable idle air
bypass screw, located right in the middle of the
ventries, that eliminates need for holes in throttle
plates.
2011 Kawasaki Z1000
Offline 1 Wild R/T
« Reply #22 on: September 07, 2014 - 11:50:54 PM »
plates.
Yeah Barry Grant has it too & has for years... That doesn't help a man who wants to keep his Hemi looking stock with two Carter AFB's....
Offline cudabob496
« Reply #23 on: September 07, 2014 - 11:58:07 PM »
no one will see the holes in the trottle plates
2011 Kawasaki Z1000
« Reply #24 on: September 08, 2014 - 12:06:29 AM »
these carbs are worth anywhere from $3,000 to $4,000 on the market.
I've seen them sell for this.
I'm not drilling these.
Offline 1 Wild R/T
« Reply #25 on: September 08, 2014 - 01:13:10 AM »
Mike, where's you sense of adventure?  :roflsmiley:  Like I mentioned earlier you might try opening the secondaries slightly... Assuming the primaries are opened far enough that the transfer slots aren't able to do their job...
« Reply #26 on: September 08, 2014 - 01:22:25 AM »
Sounds like a plan after the car show next week-end.
Offline cudabob496
« Reply #27 on: September 08, 2014 - 02:21:15 AM »
could always keep the original throttle plates, and temporarily install
new ones with holes to solve the issue.
Interesting that the throttle body throttle plate, on my LS1 Trans Am, has a small hole as well.
http://www.bing.com/images/search?q=ls1+throttle+body&go=Submit&qs=n&form=QBIR&pq=ls1+throttle+body&sc=8-17&sp=-1&sk=#view=detail&id=5189C45CE1444E12A225A50AE2FF8438DD2842D2&selectedIndex=3
« Last Edit: September 08, 2014 - 04:53:03 AM by cudabob496 »
2011 Kawasaki Z1000
« Reply #28 on: September 08, 2014 - 02:10:29 PM »
Which one's do you recommend?
« Reply #29 on: September 08, 2014 - 04:50:13 PM »
what vacuum are you getting at idle in gear , the springs need too be lighter rated than the reading you get so if you have say 6" of vacuum you need 4" springs
