Plum Crazy mixing formula
Author Topic: Plum Crazy mixing formula  (Read 8982 times)
Offline challenger500
« on: April 26, 2005 - 12:34:49 PM »
Greetings all, I'm in a "desperate" need for getting asap mixing formula for Plum Crazy paint.
If someone has Dupont's mixing formula could you put me those paint codes and values asap, thanks. (I have lost somehow my piece of paper where that formula was  >:()
Dementia already from the year...mmmm ???
Offline 4Cruizn
  • HEMI FISH
Re: Plum Crazy mixing formula
« Reply #1 on: April 26, 2005 - 03:13:21 PM »
If you have an old can, the formula is usually on the inside of the label.  I thought I had lost mine to so I took my old can down to the paint store and he took off the label and there it was on the inside!!  Something to check if you have one!
« Last Edit: April 26, 2005 - 07:03:14 PM by 4cruzin »
Offline 70RT440SHAKER
    • Challenger R/T
« Reply #2 on: April 26, 2005 - 05:41:16 PM »
Here in Iceland you only bring the code C7to the paintshop and they mix the color, most of these paint producers have comparison books so it would not be a problem. My paint was base cote and clear laquer.
    • Challenger R/T
« Reply #3 on: April 27, 2005 - 03:16:37 PM »
here are the Codes I have for C7 Plum Crazy
Chrysler: AY2EB7
Ditzler Acrilyc Enamel: 2210
DuPont Acrylic Lacquer: 5182LM
Hope this helps
Offline heminut
« Reply #4 on: April 28, 2005 - 08:09:04 AM »
I can get Duponts mixing formula if that's what you need. I'll try to post it this evening.
1970 5.7 Hemi Cuda
Offline Challenger_7
« Reply #5 on: May 19, 2008 - 08:29:30 AM »
Please I need the mixing formula too, in case Dupont here do not have the correct refernce.
I would be grateful if you can help me out.
Thanks
71 Chally Conv 383 Magnum Manual - Hurst
71 Chally Auto 383 Magnum R/T 100% Orig
71 Chally Auto 400
70 Chally Auto small block
72 Charger SE Manual - Hurst
73 Plymouth Satellite "Sebring Plus" 100% Orig
Others: http://www.cardomain.com/id/Challenger_7
« Reply #6 on: May 19, 2008 - 01:29:34 PM »
a friend just had FC7 mixd by 7 different paint manufacturers & came up with 7 totally different colors , he picked the one he liked the best , all of them mixed according to the original specs for the color
Offline Aussie Challenger
« Reply #7 on: May 20, 2008 - 08:14:05 AM »
  Depends on the tint mix colors and also on how acurate the person mixing the colors wants to be. I found that scales were the best for mixing ( very slow though ), most of the other tools especially the float arrangement were a hit and miss affair. I haven't mixed paint for 20 odd years but the new electronic machines I have seen, again seem to be a very inaccurate.   :faint:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: May 20, 2008 - 10:11:15 PM »
email or call theie tech department they will give you that info. there is no reason why dupont would not have a formula for fc7. mix a quart in what ever system your going to spray and lay it down on a spare part to see what it will look like. CAUTION on your sealer coat. if you don't tint it or use a grey sealer. this will ultimately have an impact on the final color no matter how many coats of base you put down.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline FY1Cuda
« Reply #9 on: May 21, 2008 - 12:46:45 PM »
We had a local FinishMaster shop mix up some Dupont FC7 (C7 in their book) and twice it came out less intense, more silvery grey than the original.  We used it for the engine compartment, trunk, etc.  When the painter did the exterior of the car, he used Sherwin-Williams Plum Crazy and it was a dead-on match with the original paint on the inside of the doors.  I regret having used the Dupont paint because the difference is rather obvious. Based on that experience, I would not choose Dupont for FC7.
« Last Edit: May 22, 2008 - 11:53:28 AM by FY1Cuda »
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #10 on: May 22, 2008 - 01:39:08 PM »
BASF RM diamont system I have used and it looks great.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline alphabuck
    • Pics of my project
« Reply #11 on: May 22, 2008 - 05:56:35 PM »
ive only recently started to learn about paint and how to mix it.  we sell ppg.  its amazing how the formulas vary based on what sort of paint youre buying etc.
code 2210
atfc7, ay2fc7, c7, dt3358
deltron DBU                         parts                     cumulative
dmd624 violet                      270.9                     270.9
dmd1687 med aluminum          228.8                     499.7
dmd614 blue                         56.0                       555.7
dmd1686 fine aluminum           28.1                       583.8
dmd622 red oxide                   28.1                       611.9
dx685 urethane flattening        18.7                       630.6
dbx1689 clear                        373.5                    1004.1
delstar DAR
dmr450 violet                         796.7                     796.7
dmr433 med aluminum              110.4                     907.1
dmr491 black                            87.5                     994.6
dmr476 red                                 9.9                    1004.1
dmr495 catalyst                        19.9                      1024.24
duracryl DDL
dma357 violet                         122.1                      122.1
dma323 coarse poly                   34.6                      156.7
dma359 light red                        20.4                      177.1
dma349 fine aluminum                 10.1                       187.2
dma311 white                              2.0                       189.2
dma310 clear                             814.2                     1003.4
might not help you in your dupont search im not sure if you can just cross the numbers?
Offline farmboy70
« Reply #12 on: May 23, 2008 - 10:15:02 PM »
PPG DBU is a good match to original, the trick is not to spray lite or dry. The metalic tends to lay on top causing it to wash out and look too silver.
