Author Topic: Cleaning out gas tanks and fuel lines  (Read 4051 times)
Offline Blasterb
« on: September 12, 2014 - 01:30:38 AM »
Before I got my Challenger it was in storage for a long time. The gas in the tank is sour and I'm having my carb restored. I want to thoroughly clean my gas tank and flush the fuel lines before re-installing the carb. The tank was replaced by the former owner just prior to putting it in storage so it is in excellent condition otherwise I'd probably just replace it. Anybody got any experience/hints for accomplishing this task?
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Cleaning out gas tanks and fuel lines
« Reply #1 on: September 12, 2014 - 10:47:48 AM »
I usually use Cooler clean for my gas lines.  Then blow them out with brake cleaner after the cooler clean.  Personal preference.
Cooler clean has screw on ejectors for cooler lines, but I just tape the tube end to my fuel line.  Works for the short period your pushing the stuff through.
Then I blow compressed air through the lines, this push's out any excess fluid and helps evaporate any brake cleaner left.
Tanks, I usually use a power washer honestly.  Blow everything out multiple times and then dry the tank with a heater.  I put the gas tank up above the heater for a couple days.
This is what I found three tank cleans ago.
Offline Blasterb
« Reply #2 on: September 12, 2014 - 05:18:59 PM »
That's a lot of rocks!
Offline Blasterb
« Reply #3 on: September 13, 2014 - 09:34:41 PM »
Drained the tank, last half didn't smell so bad. Flushed the fuel lines with carb cleaner. Debating whether to pull the tank or not. While I was at it figured out why my gas gauge didn't work-not hooked up. Anybody have a pic of where the wire goes through the floor of the trunk?
Offline dakota
« Reply #4 on: December 20, 2014 - 09:22:26 PM »
Just adding to this thread for reference purposes.
I could tell by the rattling that there was a lot of crap inside my fuel tank.   I have already ordered a new one, so I thought it might be interesting to open up the old one to see what the inside looks like under some brighter lights.  This took just a few minutes with an air chisel.   There's no difference between the darker material and the lighter stuff other than the darker stuff was wet with water.
« Last Edit: December 21, 2014 - 07:03:18 AM by dakota »
Offline CHL2T
  • Handle it, man!
« Reply #5 on: December 21, 2014 - 12:45:22 AM »
Amazing what old gas turns into, my former Cuda had at least as much as the other two tanks pictured.......
« Reply #6 on: December 21, 2014 - 07:49:10 AM »
Wow that had to be a kid putting them in?  :clueless:   My tank had a big pile of rust in the bottom so I just replaced it.
Offline DocMel
« Reply #7 on: December 22, 2014 - 06:12:57 PM »
Myself, if I get storage crud in my tank, I changed out the tank for a new one.   You will just keep running into clogged this and that, and fine particulate and tar will get into your carb and engine, causing more problems.
Offline jimynick
« Reply #8 on: December 22, 2014 - 10:54:51 PM »
Why not just take the tank off? You said it had recently been replaced, so pull it down and take out the sender and apply the MkI eyeball and see where you are. Gas won't turn into rocks, not if you left it for a 1000 years. What you're probably dealing with is schmutz from old and contaminated gas station tanks. Clean it out, if req'd, blow the lines clean and put 2 or 3 of the cheap transparent in-line fuel filters on it, in series and run a tank of gas through it and check the filters- if they're clean- you're golden. Have a gas! Sorry, couldn't resist.  :cheers:
« Reply #9 on: December 23, 2014 - 11:30:39 AM »
Surprisingly enough there was no rust at all in the tank.  Dry north western TExas car.
I think all the rocks helped keep the scale down as it drove around.
Kind of like sand blasting the inside of the tank at every bump and curve.
Dang kids !!!  Or Ex Girlfriends !!?
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #10 on: December 23, 2014 - 11:38:18 AM »
Offline roadman5312
« Reply #11 on: December 23, 2014 - 11:41:25 AM »
                or ex WIVES    :scared:
Offline DocMel
« Reply #12 on: December 23, 2014 - 03:10:58 PM »
I had a serious problem with stalling in a couple of vehicles I restored:  A 1969 MUTT (military "jeep") and a 70' 340 Cuda. Both vehicles had sat for a long time. It really drove me nuts.  They would just hiccup, sorta stall, run, and repeat.  No pattern.  Sometimes it got so bad the engine would sputter and quit
So I removed the bowls on the carbs on both vehicles.  Very fine rust particulate in both bowls.  I cleaned the bowls,  changed out fuel filters, it would run ok for a time, then it would keep happening.  The bowls were full again of the fine rust.  So I looked in both tanks.  With a flashlight and eyeball, what you could see looked great:  The typical clean and grey galvanizing that one would expect, at least in my very limited field of vision.
But when I took the sending units out, I could take my finger, rub it along the inside the tank, and I would get a what looked like red mud:  It was rust, as fine as you can imagine.  Any in line filter or sock I would run would still let some of it thru.  And cleaning and flushing the tank did not help. The symptoms would eventually reoccur:  Once a tanks rust inside, its pretty much over and will continue to do so
If you have ANY doubts on an old tank, get rid of it get a new one.  The cost of a new one, to me, isn't worth a cleaning or "lining" of an old tank, especially when the tank has to come out in the first place.
Offline anlauto
« Reply #13 on: December 23, 2014 - 04:00:14 PM »
 :iagree: I put new gas tanks in all my restorations. I've only ever had problem with one car not running well and it ended up being the used gas tank the customer supplied. He had it refurbished and whatever they used went through the fuel system and clogged up the carburetor. :swear: Never again.
Offline jimynick
« Reply #14 on: December 23, 2014 - 11:53:21 PM »
That's funny and coincidental. My son recently rebuilt a Mutt for a friend and the tank was a real mess. As it was only under the seat we pulled it and flushed it and coated it with a 2 part epoxy we bought made for the purpose and all seems well. I really hope there's no issues with the epoxy, since I also used it on the tank for my old Yamaha Venture.  :o
