Author Topic: Charging issues  (Read 3517 times)
Offline Beekeeper
Re: Charging issues
« Reply #15 on: September 16, 2014 - 12:07:59 AM »
Ok, sounds good. That's on my list this weekend. I'll run 8 gauge just to be safe. If I get bored, I'll rewrap the harness to give it a nice clean factory look.
So after doing this, I'll run the engine a while to get the battery topped off then check the voltage at the alternator and the battery. If I understand correctly, it should be almost the same since there is now so little resistance.
I'm always a little paranoid of electrical stuff, probably because I understand it the least of all my cars workings. I plan to keep checking it regularly too in case the alternator is acting up.
Thanks for all the great advice.
Re: Charging issues
« Reply #16 on: September 16, 2014 - 12:15:30 AM »
correct , the voltage should be very close to the same at the alt & Battery , I usually run the bypass around the engine compartment instead of across the engine , just less chance of it getting melted or damaged that way
Offline Beekeeper
Re: Charging issues
« Reply #17 on: September 24, 2014 - 09:03:25 PM »
So I ran the 8 ga wire as a bypass. It worked great! The ammeter needle doesn't move much which is fine. The voltage is steady at 14.8 volts at battery and alternator. Hoping I never have battery issues ever again!  Thanks for the help guys.
Re: Charging issues
« Reply #18 on: September 25, 2014 - 01:32:00 AM »
 :2thumbs:
Offline jhaag
Re: Charging issues
« Reply #19 on: September 30, 2014 - 10:05:15 PM »
what gauge wire runs from the starter relay to the battery on an OE style battery cable? Is it smaller than 8 gauge? If so doesn't that defeat the purpose?
love 70 Challengers
Re: Charging issues
« Reply #20 on: September 30, 2014 - 10:07:25 PM »
It's #8 or #10 i think.
Offline Beekeeper
Re: Charging issues
« Reply #21 on: September 30, 2014 - 10:11:16 PM »
It looks like 8 to me.
Offline jhaag
Re: Charging issues
« Reply #22 on: September 30, 2014 - 10:47:02 PM »
Thanks, I bought a generic and the pigtail looks like it is 14 gauge.
love 70 Challengers
