Author Topic: 1970 cuda 340 six speed manual help  (Read 585 times)
Offline sixbarrel
« on: September 14, 2014 - 04:17:12 PM »
I'm thinking about putting a six speed manual in my car it's a 4 speed now looking on line not seeing a lot of option's does any body know of any newer tranys that would work or just a good trany to look at.
« Last Edit: September 14, 2014 - 05:46:38 PM by sixbarrel »
Offline anlauto
Re: 1970 cuda 340 six speed manual help
« Reply #1 on: September 14, 2014 - 04:40:33 PM »
I think up grading to a 6 speed means relocating the shifter to the center of a modified transmission tunnel.
A 5 speed up grade is more common. You can go with a Passion 5spd (direct bolt in) or a Tremec 5 spd which requires modifocations but the shifter is still in the stock location.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #2 on: September 14, 2014 - 04:57:25 PM »
Consider keeping your A833 and add a Gearvendors Overdrive
You can split every gear... Hoping Santa will bring me one.
If you part with your car put it back the way it was and keep the OD for your next.
https://www.gearvendors.com/hrdodge4sm.html
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline sixbarrel
« Reply #3 on: September 14, 2014 - 05:44:00 PM »
Thanks for the info I will research both ideas
« Reply #4 on: September 14, 2014 - 08:13:15 PM »
I would skip the Tremec option , The Passon 5 spd or the GV are the best way to go
