Author Topic: Trouble starting, again  (Read 6445 times)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« on: September 14, 2014 - 05:19:03 PM »
So I tried to start my chally today, been a whiiiiiiiile, cranks just fine.  If I pour some gas in the carb it will fire for a second or two then die.  Now, when it's cranking, my fuel pressure guage at the carb is bouncing around 6psi or so.  So it's claiming to be getting fuel, but it only starts when I dump fuel into the carb.  Thoughts?
1973 chally
'70 340 12:1 dome pistons
J heads, 2.02/1.60
Eddie air gap
750 Holley street avenger elec choke
Factory electronic ignition & dist
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Trouble starting, again
« Reply #1 on: September 14, 2014 - 09:42:55 PM »
Bump!
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline jhaag
« Reply #2 on: September 14, 2014 - 09:49:15 PM »
did you pull the sight plugs? fuel in the bowls? do you get a shot from the accelerator pump when you move the throttle?
love 70 Challengers
« Reply #3 on: September 14, 2014 - 10:53:42 PM »
is the pump electric or mechanical ?
 the carb may be evaporating dry after running with the alcohol in the fuel etc & the heat of the engine so the carb may be dry , if it is electric the carb should fill quickly , if it is mechanical it will take 30 second of cranking to fill it back up .
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #4 on: September 14, 2014 - 10:55:48 PM »
Thanks guys, it's a mechanical pump, I'll take a look at it tomorrow to see if the bowels are filling
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #5 on: September 15, 2014 - 01:34:20 PM »
Ok, I can see the bowls have fuel, but still won't start, still fires for a second if I put gas straight into the carb.  Otherwise just keeps cranking on the verge of starting, keeps starting like it's going to fire but never does, just keeps stumbling.
« Last Edit: September 15, 2014 - 07:00:54 PM by moparman82 »
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #6 on: September 15, 2014 - 07:01:08 PM »
Bump updated
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline ToxicWolf
« Reply #7 on: September 15, 2014 - 07:39:35 PM »
It still sounds like it isn't getting fuel or it doesn't like the gas in the tank.  How old is the gas in the tank?  Since it starts when you pour fuel in the carb, doesn't seem to be a spark problem.   :clueless:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #8 on: September 15, 2014 - 07:46:50 PM »
It was basically empty, I put a couple gallons of fresh 93 in the tank and used a bottle to fill the bowls with the same
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #9 on: September 15, 2014 - 08:15:23 PM »
any choke > too lean without it maybe ?
are you getting steady spark while cranking , reluctor gap Ok ?
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #10 on: September 15, 2014 - 08:25:31 PM »
Hey chryco, it's has an electric choke but it doesn't seem to be working.  When I hold the choke manually I get that continuous stumbling on the verge of running.  All the plugs are less than a year old and the car was running when we moved back in May.
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #11 on: September 16, 2014 - 12:08:24 AM »
no vacuum leak or hoses unhooked or split
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #12 on: September 16, 2014 - 10:16:37 AM »
Nope, I'm thinking maybe accelerator pump? I'm gonna check today to see if I'm gettin any fuel squirting when I flick the throttle
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline mopar jack
« Reply #13 on: September 16, 2014 - 11:30:09 AM »
How do you initially try to start the car? With the key off and the choke open I would give the throttle 2 full pumps to the floor then hit the starter. If there is fuel there it will start and you will have to feather the throttle a couple of times to keep it running. Been doing it like that for years on my mopars with no choke,
Jack
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Trouble starting, again update
« Reply #14 on: September 16, 2014 - 04:47:33 PM »
Ok, so I pulled the good off, took off the air cleaner, filled the bowls with fuel, and worked the throttle with my hand.  When I slam it to wide open, there is a just a drizzle of fuel, I was under the impression it should be a strong stream of fuel when I do that?  Does that mean accelerator pump?
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
