Author Topic: Trouble starting, again  (Read 6443 times)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Trouble starting, again
« Reply #30 on: September 19, 2014 - 08:48:03 AM »
Here we go guys, ping hits right at the 6 second mark
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #31 on: September 19, 2014 - 08:52:50 AM »
98% of the time when it's idling, there is no ping, like this
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #32 on: September 19, 2014 - 09:18:44 AM »
You need to make this video public so we can see.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #33 on: September 19, 2014 - 09:22:57 AM »
Done, thanks dan
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline dfrazz
« Reply #34 on: September 19, 2014 - 09:29:12 AM »
Sounds like a backfire and the idle dips way down almost killing the engine, unless I am not hearing this correctly (I am getting older).
Offline HP_Cuda
  • Mopar or No Car!
« Reply #35 on: September 19, 2014 - 01:14:34 PM »
Sounds like a backfire to me as well.
Now to figure out why - especially if its intermittent.
Does it only happen when you are rev'ing the motor?
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #36 on: September 19, 2014 - 02:09:36 PM »
Got the revs up a bit more today and got a big ole fat backfire, no question about it....what Te the most common causes?
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline ShelbyDogg
« Reply #37 on: September 19, 2014 - 02:10:23 PM »
Sounds like you have a plug wire on the wrong plug. Check your firing order again. Did you have any plug wires off when you rebuilt the carb?
A lean misfire would pop when you are giving it gas, yours was when it was just idling.
Offline mopar jack
« Reply #38 on: September 19, 2014 - 04:32:04 PM »
Check the coil for oil leakage. A bad coil can cause all sorts of random spark issues. In your early post you thought the sound might be metallic. If your running an auto trans check the torque converter bolts.
Jack
« Reply #39 on: September 27, 2014 - 07:58:22 AM »
As well, if you find they are all in the right order, pop off the dist cap, check the rotor gap (as cp suggested earlier), check terminal condition, and all wires seated fully after the cap in put back in place.
I had a persistent backfire two years ago that I eventually traced to a cracked #3 cyl header tube very close to the head. So check that your headers are sealing well against the head and that none of your plug boots have burned being too close to a tube.
« Reply #40 on: September 27, 2014 - 09:34:16 AM »
The reluctor could be in the wrong position also there are 2 keyways with a different keyway depending on rotation
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #41 on: September 27, 2014 - 10:59:04 AM »
Thanks for everything guys, looks like cArb tuning and timing did the trick!
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #42 on: September 27, 2014 - 02:45:47 PM »
 :2thumbs:
