Author Topic: Torsion bar fitment  (Read 2392 times)
Offline Priesty
Torsion bar fitment
« on: September 21, 2014 - 07:41:21 PM »
Hi guys,
Just received my new torsion bars & preparing to reassemble whole front end. I know the torsion bars are marked LH & RH, is there a front & back, or does it not matter which way they go in ?
Sorry if it's a stupid question, just don't want to get it all back together & have to pull it apart again.
cheers......
Steve - 72  BS23  FY1  'Cuda.
Melbourne, Australia.
The term "Foolproof", seriously underestimates the ingenuity of fools.
CUDA Crop by steve, on Flickr
Offline blown motor
Re: Torsion bar fitment
« Reply #1 on: September 21, 2014 - 07:52:12 PM »
Don't forget the boots and don't ask me how I know that  :faint:
« Reply #2 on: September 21, 2014 - 07:52:54 PM »
No front and back , just left and right.  :wave:
« Reply #3 on: September 21, 2014 - 08:52:31 PM »
drop the lower control arm to full drop to line up the sockets , I usually coat the end with grease so they do not rust in & if there is a 3 digit part # on the end I leave that showing so you can tell later exactly what bar is in there without pulling them
Offline 72bluNblu
« Reply #4 on: September 21, 2014 - 10:45:44 PM »
Exactly! If there's a part number on one end, leave that end showing. Makes life a lot easier later if you forget what you've got. If it doesn't have a part # (some aftermarket bars don't), leave the "L" and "R" stamping showing. Again, just for piece of mind later.
Offline crash340
« Reply #5 on: September 22, 2014 - 04:39:25 AM »
what bars did you go with Priesty
Greg
73 Cuda
Brisbane, Australia
Offline Priesty
« Reply #6 on: September 23, 2014 - 05:20:29 AM »
Bought some .92" bars as my LH original .89"? was bent. Also bought a Borgeson strg box & bergman adaptor kit for the coupling. After I had the strg box out I got a nasty surprise, when I looked at the frame rail there was a very dodgy rust repair job, spent last 3 days fixing it & some other parts on the frame rail. Ready to all go back together now though. All new BJ's & control arm bushes as well.
Thanks for advice on the torsion bars guys will do as you suggest.
« Reply #7 on: September 23, 2014 - 09:13:37 AM »
Might want to have a read....? http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=8128289&an=0&page=0#Post8128289
Some people are into a nightmare with those steering boxes? Some seem ok , ..... some not!
Offline BIGSHCLUNK
« Reply #8 on: September 23, 2014 - 09:46:18 AM »
:roflsmiley:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Priesty
« Reply #9 on: October 09, 2014 - 05:08:12 PM »
Finally got torsion bars in & Borgeson box fitted up. Only small amount of grinding on rear of housing & one spacer washer to make it fit. No problems with pitman fit on the spline at all (small 1 1/8 shaft).
Biggest PITA was the coupler rebuild.
Is there a trick to clamping that seal retainer on properly ? I can't seem to get it on snug.
Otherwise all good, steering already feels more responsive, although not back on the ground yet.
« Reply #10 on: October 09, 2014 - 09:03:53 PM »
Never easy , I bend the lock tabs first & snap it on , never was able to get ti tight once it is on
Offline 74 challenge
« Reply #11 on: October 10, 2014 - 08:09:20 AM »
This just changed my life, mine was always coming off.
1-8-4-3-6-5-7-2
« Reply #12 on: October 10, 2014 - 08:55:49 AM »
I used a hole saw to make a hole in a piece of 1x6.  I slid the steering shaft through the hole and then assembled the coupler.  I used another 1x6 on the bottom of the coupler which gave me something to clamp against.  With the retainer clamped in place, I just bent the tabs with a punch.  Obviously I didn't have my steering column assembled yet.  If you went this route, you'd have to cut the 1x6 off of the steering shaft.
There is an updated coupler seal that I was tempted to buy.  It does away with the metal retainer.  The updated seal is $25 though.
« Last Edit: October 10, 2014 - 09:06:16 AM by burdar »
