Cleaning satins/burned oil off ceramic headers
Author Topic: Cleaning satins/burned oil off ceramic headers  (Read 2133 times)
Offline DocMel
« on: September 22, 2014 - 07:03:39 PM »
Small oil drips staining ceramic headers:  How do you clean them off?
Re: Cleaning satins/burned oil off ceramic headers
« Reply #1 on: September 22, 2014 - 08:17:28 PM »
To the best of my knowledge, you can't.
Offline vinb
« Reply #2 on: September 23, 2014 - 09:07:17 PM »
 From a header coating company: To maintain a beautiful finish and prevent corrosion for years to come, periodic maintenance of the coating is required. We recommend periodic cleaning of your parts to remove road grime, salt and oil from the coatings and any non-abrasive aluminum polish for heavily oxidized or stained coatings.
Stains such as oils, transmission fluid and antifreeze can be easily removed with fine steel wool or Scotchbrite™ (red) and any non-abrasive aluminum polish. After removing the stains, polish to a high luster with the aluminum polish and a soft cloth.
Hope this helps..
Offline 4 speed fish
« Reply #3 on: September 23, 2014 - 09:27:06 PM »
If you use a scotch pad do not press hard or you will dull the finish.I used a red scotch brite and WD40 on a friends and it work great.Test whatever you use on the backside first.
