Author Topic: VIN # Emblem on Dash Pad  (Read 2823 times)
Offline flagcraig
« on: September 23, 2014 - 02:13:48 PM »
I am replacing my dash pad.  Is it possible to get the vin # emblem off the old dash and put on new dash?
If not, can you order a new one and then I put up the old one for safe keeping.
Thanks.
Offline anlauto
Re: VIN # Emblem on Dash Pad
« Reply #1 on: September 23, 2014 - 03:05:18 PM »
Just remove the rivets and rivet it on the new dash....easy peasy :2thumbs:
Offline ec_co
« Reply #2 on: September 23, 2014 - 03:25:10 PM »
what Alan said. drill out the old rivets and use the VIN tag on the new/fixed dashpad. you can get the rivets through a few vendors.
there can be some tricky legal issues with someone re-creating a VIN (potential for fraud), so just re-use your original
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline flagcraig
« Reply #3 on: September 23, 2014 - 04:05:25 PM »
Will do.  Thanks.
« Reply #4 on: September 23, 2014 - 04:54:53 PM »
Be careful removing the original rivets.  If you try drilling them out, they will spin and damage the VIN plate.  It's best to grind off the rivet from the back side.  The top section will push right out once the back is ground down.
You can get a new Chrysler dry transfer and the correct rivets from ECS Automotive.
Offline Katfish
  • 70 Challenger
« Reply #5 on: September 23, 2014 - 07:33:26 PM »
Good advice above, it looks better after paint and new silk screen logo.
Offline anlauto
« Reply #6 on: September 23, 2014 - 08:46:12 PM »
Silk screen looks nice, not sure I like the blue inspection mark :screwy:
Offline flagcraig
« Reply #7 on: September 24, 2014 - 01:10:48 PM »
Great help.  Thanks a bunch.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #8 on: September 25, 2014 - 12:42:51 AM »
Similar to what has already been said, I recently had a new dash pad done by Just Dashes.  I removed the VIN plate from the junky repop pad that the previous owner installed by drilling/grinding the old rivets.  I bought the kit from ECS which included the dry-transfer for the Chrysler logo and the rosette rivets.  I stripped the old paint off the VIN plate, repainted with SEM Trim Black, applied the dry-transfer logo, and had Just Dashes attach it to the newly made pad.  Worked out flawlessly.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #9 on: September 25, 2014 - 10:32:09 PM »
did you send the vin tag into Just Dashes when they installed it?
did you insure the package you shipped the vin tag in?
How did you protect yourself from loosing the tag and having to deal with that whole fiasco?
Offline shawge
  • Zoiks!!
« Reply #10 on: September 25, 2014 - 11:01:19 PM »
I think filmsurgeon lives close to Just Dashes so he drove over w/ the VIN tag and rivets and had them install it on site.
- Jerry
Offline filmsurgeon
« Reply #11 on: September 26, 2014 - 12:02:15 AM »
Exactly!!  They riveted the VIN plate to the new pad (while I waited) when I went there to pick it up.  Great team of guys, BTW.
