Author Topic: Rally Dash wiring questions  (Read 5868 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: Rally Dash wiring questions
« Reply #15 on: September 26, 2014 - 04:30:12 PM »
The one listed for radio is in the picture below and it's next to the yellow connector.
Can you take a pic of the other one with the blue wire? I believe the one you are talking about is used to plug into the flasher near the ash tray.
« Last Edit: September 26, 2014 - 04:31:48 PM by HP_Cuda »
Offline 6771plymouth
  • john
« Reply #16 on: September 26, 2014 - 04:32:13 PM »
hey danbob it looks like your car is b5 blue  coild you post some pics im also building a b5 cuda would like to
Offline Danbobracer
« Reply #17 on: September 26, 2014 - 04:45:49 PM »
6771plymouth the car is actually GB2.
Offline Danbobracer
« Reply #18 on: September 26, 2014 - 04:52:32 PM »
The one with the blue wire is pictured in one of my first posts on this thread and it's right next to the yellow wires you just posted a pic of? Thats the one i thot was for radio, but that being said, whats the one just like it but without the blue wire that is over by the ash tray for?
Also, What are those yellow wires for?
Thanks for your help.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #19 on: September 27, 2014 - 01:56:16 PM »
Tom already pointed out - Yellow bullet connector/wires is battery accessory
Someone added a blue wire to your radio plug - I would trace the blue wire and see where it goes because you will find it probably is used for another accessory.
As for the other one that is near the ashtray thats for the flasher unit. It plugs into the side of the ashtray to stay out of the way.
Offline Danbobracer
« Reply #20 on: September 27, 2014 - 02:48:38 PM »
Ill check that out when i get home from work this afternoon. Thank you. Do you know where i could get a parking brake light switch?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #21 on: September 27, 2014 - 02:49:44 PM »
Rockauto has them no problemo.
Offline Danbobracer
« Reply #22 on: September 27, 2014 - 03:44:21 PM »
HP_Cuda i just checked out rock auto and the have four switches listed under the brake light switch.  This is the only style that looks anything like it would work as a parking brake switch. Is this what you use? and then just ground one tab? Since they don't list it as a parking brake light switch i want to make sure i order the right thing.
