Author Topic: swap 70 rally gauges into a 72?  (Read 1307 times)
Offline mach3107
« on: September 25, 2014 - 11:22:55 PM »
I have a 72 challenger with NON rally gauges. My friend has a former drag car (70 challenger) with rally gauges. I want his rally gauges in my 72. Will they fit directly in or will I need the whole dash frame too? I've held the woodgrain plastic behind my steering wheel and it doesn't seem like it will fit correctly.
Thanks for any input.
Offline Beekeeper
Re: swap 70 rally gauges into a 72?
« Reply #1 on: September 25, 2014 - 11:45:12 PM »
I seem to recall hearing that the dash frame itself is the same for 70-74 but I couldn't say on the column and any trim around that area. My guess is they will work but I'm still learning the E bodies myself. Hopefully someone knows for sure.
Offline 73Chally
« Reply #2 on: September 26, 2014 - 08:59:42 AM »
Should be a direct swap as far as fitment, but you'll need to modify the dash harness to work with the new gauge cluster.  You'll also need to run a wire from the coil to the tach, along with a 12V source to power the tach.
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: September 26, 2014 - 12:33:29 PM »
 :iagree: :iagree: :iagree: :iagree: :bigsmile:
74 'cuda 360/727
Just call me a gearhead!
Offline dutch
« Reply #4 on: September 26, 2014 - 02:35:45 PM »
sell the 70 cluster , purchase a 72+ cluster and keep the change...  :2cents:
*** Bart ***
Offline CHL2T
  • Handle it, man!
« Reply #5 on: September 26, 2014 - 03:40:27 PM »
Exactly, someone here could use a set of 70 gauges........ :drool:
First dibs, right here!  lol
Offline vert
  • Looking good, Billy Ray! Feeling good, Louis!
« Reply #6 on: October 01, 2014 - 05:46:04 PM »
You should work with me on this.  I have a 72-74 rallye cluster and a 71 car.  I was trying to make the 72-74 unit look correct.  We should talk trade...
71 Barracuda | Hemi idling | Hemi Dyno pull
