Author Topic: 1969 340 to a hemi torque converter.  (Read 6975 times)
Offline Denison636
« on: September 26, 2014 - 11:59:38 PM »
Need some help on seeing if they make a hemi converter that will fit a 1969 340. I found out that the nose of the converter will not fit my crank tonight when putting in the tranny. Tranny is a 727. Any help would be great.
Thanks,
Denny.
Its just a little 340 with a miss
Offline Denison636
Re: 1969 340 to a hemi torque converter.
« Reply #1 on: September 27, 2014 - 01:01:15 AM »
I am hoping to get some information by Monday so I can go to the tranny shop and get this straight. This kinda rumored my hole weekend due to I am putting in a new drive train and this stop me on the tranny.
Offline BIGSHCLUNK
« Reply #2 on: September 27, 2014 - 01:09:21 AM »
I;m a little confused as to what you want to do, But a HEMI trans (BIG block) wont bolt to a small block (340)  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Denison636
« Reply #3 on: September 27, 2014 - 01:53:39 AM »
I have a small block tranny and a small block motor. Have the right flex plate but my question is is there was different years on hemi converters. I have one on my tranny that my Tammy shop told me would work but the nose of the converter is to big for the crank. It puts the converter into a bind.
Offline Denison636
« Reply #4 on: September 27, 2014 - 01:54:20 AM »
Tranny shop. Sorry still trying to learn how to spell and type.
Offline Denison636
« Reply #5 on: September 27, 2014 - 01:56:43 AM »
Looking for a converter that the nose of it will work on my 340.
I figure I would ask everyone on here due to a lot people look like they know there stuff and I am new to the mopar world.
Offline BIGSHCLUNK
« Reply #6 on: September 27, 2014 - 10:22:20 AM »
Questions are good, lots of good tech advice here. Can I ask why you want to use a hemi converter.  :clueless:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: September 27, 2014 - 12:27:25 PM »
I would contact a converter builder , they should know why the nose diameter would be different , I assume the 426 Hemi 8 bolt cranks use a different hub size but I am not sure why . I am sure the correct converter can be built to the same spec as the Hemi converters internally
Offline Denison636
« Reply #8 on: September 27, 2014 - 12:53:39 PM »
I need a stall for my cam and my tranny guy talked me into this converter. I figured it sounded to good to be true. Well I can tell you that bolts line up. It is an internal balance and starter ring gear even was right. Guess it time I throw this back at my tranny guy and see what els he can get for a big stall.
I got a 282/290 duration solid cam in a little 10.5:1 340.
« Reply #9 on: September 27, 2014 - 03:14:27 PM »
could you trim downthe front hub on a lathe ?
Offline Denison636
« Reply #10 on: September 28, 2014 - 04:43:42 AM »
Maybe could but not sure on how thick the metal is.
Offline Denison636
« Reply #11 on: September 29, 2014 - 02:56:48 PM »
Talked to my tranny guy and there is a hemi converter that will work. This is what he says anyway. I am only going with this due to I want the 2800 stall for my car. Don't want to go to big due to I have a gear venders unit on my 727. Also only have 3.91 gears. I know I am pushing the limits with the cam.
I will keep everyone posted on how things work out.
Thanks for the help.
Offline Denison636
« Reply #12 on: October 10, 2014 - 06:50:54 PM »
Well I found out that on a 340 my tranny guy did not know what he was talking about and well I got my money back today. I ordered one from my local speed shop to match my set up.
Offline BIGSHCLUNK
« Reply #13 on: October 10, 2014 - 10:29:34 PM »
now this is making sense........  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline jimynick
« Reply #14 on: October 10, 2014 - 11:55:22 PM »
You can turn the nose of the converter as CP suggested and I've done it, trying to mount an A engine TF to a LA 318 years ago, BUT, don't cut it much as it's about .060 thick. Guess how I found this out.  :swear:
