Author Topic: AAR Hood on a Challenger  (Read 2333 times)
Offline myrtle
« on: September 28, 2014 - 04:17:24 AM »
Anyone done this? Interested in some pics if so. Im not a fan of the T/A hood, Shaker are too expensive and i want something different than the reg RT Hood.
1970 GTX. #s Matching Super Track Pack
Offline kissalien
Re: AAR Hood on a Challenger
« Reply #1 on: September 28, 2014 - 11:48:56 AM »
It won't fit.
Offline anlauto
« Reply #2 on: September 28, 2014 - 11:50:02 AM »
It'll fit, might just come up a little short... :grinyes:
« Reply #3 on: September 28, 2014 - 12:33:34 PM »
Something like this?
Offline myrtle
« Reply #4 on: September 28, 2014 - 03:38:05 PM »
Yes, just like that. Why does everyone say the hood won't fit? Are they not interchangeable between E Bodies?
Offline anlauto
« Reply #5 on: September 28, 2014 - 03:44:23 PM »
Cuda's have a seperate "header panel" in front of the hood between the fenders. Challenger do not. :2cents:
Offline myrtle
« Reply #6 on: September 28, 2014 - 04:15:57 PM »
Gotcha. And Im guessing that header panel won't fit the Challenger with out the Cuda Fenders?
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #7 on: September 28, 2014 - 04:20:05 PM »
It would probably be easier to build one out of a FLST chally hood.  I looked into this a dozen times, I begged US body source to make a SRT10 ram style hood for my chally haha no luck.  They do make a 07-10 srt8 charger hood for a-bodies and certain b-bodies that  looks bad a$$
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
« Reply #8 on: September 28, 2014 - 04:40:24 PM »
It may not match up well with the Challenger grill structure. Certainly if you are motivated, it could be made to work, but you do have different body lines and features to contend with. You could mount the Cuda header between challenger fenders, cut the front off a Challenger hood and mount to the Cuda hood. Cut the front off a Challenger hood and turn it into a header panel. Or source an AAR style hood and cut the scoop off and graft to the Challenger hood.
Mine is actually a Cobra Jet scoop that has had the edges and opening extended with additional ABS pieces to smooth the transitions so it looks more like an AAR than a CJ. If you look closely at the picture below, you can see the seams where it started to de-laminate and pull apart after several years of sun and engine heat. You also can see the body lines unique to Challengers that carry from the fenders into the hood that the Cuda does not share.
