70 Challenger 3gen,T-56,modern suspension
Author Topic: 70 Challenger 3gen,T-56,modern suspension  (Read 36137 times)
Offline swe_challenger
« on: September 29, 2014 - 11:17:44 AM »
I've come halfway with restoring and thought put out some pictures of the project.
The car comes from Des Moines Iowa, and I imported it to Sweden in 2009.
360cui,manual, 8.75. The car looked to be in reasonable condition
Drove the car 2 summers 2009,2010. started the renovation in 2011 which was supposed to be a rolling refurbishment.
The first thing that should be changed was the gearbox to a Viper T-56, but I had to start from scratch after discovery of much rust.
« Last Edit: October 09, 2014 - 04:18:11 PM by swe_challenger »
Stefan Alvsbyn Sweden
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 70 Challenger 3gen,T-56,modern suspension
« Reply #1 on: September 29, 2014 - 11:43:53 AM »
WOW!  That is one sweet looking Challenger. What are your next steps to finish? Please post more pics and video if you can!  Great job!   :ylsuper:
« Reply #2 on: September 29, 2014 - 11:51:41 AM »
Thanks.
I found way too much that I did not like, just start working !!
The hole-body got a sandblasting and epoxy primer.
« Last Edit: October 09, 2014 - 04:17:21 PM by swe_challenger »
« Reply #3 on: September 29, 2014 - 01:21:55 PM »
With the old 360 engine connected to the T-56 box, there was not enough space for the gearbox.
In the pictures you can see that I have replaced parts of the driver's side floor and a bit of the back.
I do the best I can with my limited welding skills
With practice it gets better and better
« Last Edit: October 09, 2014 - 04:15:56 PM by swe_challenger »
« Reply #4 on: September 29, 2014 - 02:07:00 PM »
Nice work so far.
However, I didn't see the trans/t-bar cross member replaced with the new transmission tunnel after it was cut out. If you are retaining the torsion bar front suspension, you will need to rebuild this support piece or you will risk future body twist and suspension problems.
« Reply #5 on: September 29, 2014 - 02:49:29 PM »
Time to make new mounts to the sport seats from Italian OMP.
Third time lucky, it was either to high/low or to near the propshaft tunnel.
Test mounted the  hydroboost Power Brake Package, looks good.
Smoothing up the firewall and inner fenderwells  from holes and others.
I will hide the power cables as much as possible behind the fenders.
« Last Edit: October 09, 2014 - 04:12:05 PM by swe_challenger »
« Reply #6 on: September 29, 2014 - 03:09:03 PM »
Nice work so far.
I bought AlterKtion coil-over system from Bill Reily Motorsports.
I have made new stronger trans cross member, do you think I need to do more reinforcements?
The picture shows the new cross member.
« Last Edit: October 09, 2014 - 04:10:26 PM by swe_challenger »
« Reply #7 on: September 30, 2014 - 12:08:38 PM »
If you are using an AlterK, then you are going to be fine.
The lower transmission mount you show is also fine. I was concerned that you cut out the upper portion that runs through the transmission tunnel to fit the T56.  This cross member will see a lot of stress if you use the stock torsion bars because they are anchored in that same cross member.
« Reply #8 on: September 30, 2014 - 03:18:00 PM »
Front suspension before powder coating.
Installed with Wilwood brakes.
13" front disc brakes, drilled/slotted, SL6 calipers
« Last Edit: October 09, 2014 - 04:09:54 PM by swe_challenger »
Offline soundcontrol
« Reply #9 on: September 30, 2014 - 03:48:25 PM »
Nice work! What brand of epoxy primer did you use for the body?
/Ken
/ Ken
topic=108917.new#new
« Reply #10 on: September 30, 2014 - 04:13:33 PM »
/Ken
JOTUN Penguard Express Comp.A Gray
JOTUN Penguard Express Comp.B
JOTUN Thinner No.17
« Reply #11 on: October 01, 2014 - 05:39:44 PM »
Another step is to stiffen the chassi.
Made my own lower radiator suport, front fender brace, rear crossmember and some boxes.
Front and rear driveshaft loop
Bought lasercut frame connectors from Mancini Racing.
Prepared for future front strut tower brace.
« Last Edit: October 09, 2014 - 04:09:04 PM by swe_challenger »
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #12 on: October 02, 2014 - 08:18:23 AM »
Nice work great looking car  :bigshades:
Go Fast & Have Fun...
Offline ragtopdodge
« Reply #13 on: October 02, 2014 - 08:41:15 AM »
Great job!
What color you going for?
ALso, what you going to do for rear suspension?  STock leafs and sway bar?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #14 on: October 02, 2014 - 05:08:21 PM »
Great job!
Color, I had decided from the beginning, "imperial green" because it's really neat and
if the prep work is not perfect, it becomes invisible.
The decision about a 4-link with coil overs was clear but if it would to be purchased or built was uncertain.
I thought it would be interesting to build it myself. Ideas come from Reilly Motorsports street lynx, XV Motorsports rear and from different forums.
Mancini's weld on brace for the rear.
Rear axle and drive shafts shortened approx. 1.5 inches to give the wheels more space.
Wheels and tires I used from an old Project.
The rear end is not tested yet, but it looks good.
I will come back later with some test results.
« Last Edit: October 09, 2014 - 04:07:24 PM by swe_challenger »
