70 Challenger 3gen,T-56,modern suspension
Author Topic: 70 Challenger 3gen,T-56,modern suspension  (Read 36136 times)
Offline grimmey71
Re: 70 Challenger 3gen,T-56,modern suspension
« Reply #90 on: November 30, 2015 - 12:51:47 AM »
Yes, it is McLeod RXT Twin disc setup
I think it feels great, but have not tested it for proper load yet.
Heads are SRT8 but with larger stainless steel valves and easily ported intake and exhaust.
CPR fuel rail with gauge.
http://www.cprracing.com/productFuelRailHEMI.html
Thanks, I just pulled my drivetrain and am thinking about going with that twin disc clutch, and doing some head work with a new cam. I read that that clutch is supposed to be very easy to use, not jerky and super tough
Offline jarven
  • Orange is the new black
« Reply #91 on: December 14, 2015 - 11:47:07 AM »
Vilket snyggt bygge!
There is no point in having an x-pipe when running turbos?
if it was mine I would paint the IC black..  :thumbsup:
Magnus, Arvika, Sweden, Mopar lover
Offline swe_challenger
« Reply #92 on: December 17, 2015 - 05:39:48 AM »
Tackar.....Thanks!!
X-pipes are for naturally aspirated Engines I Think!
Has never occurred to me that IC can be painted.
Perhaps I would do it ... not a bad idea  :cheers:
Stefan Alvsbyn Sweden
Offline Travis72
« Reply #93 on: December 26, 2015 - 05:23:55 PM »
Challenger is really looking amazing.  Lots of great fabrication too!!
Travis
72 Cuda
« Reply #94 on: January 12, 2017 - 06:52:37 AM »
Have a lot to update so it is best to start.
solution of my "oil scavenge problem"
Check valve with 2 psi cracking pressure installed pre-turbo and 3m.m restrictor.
Smaller catch canister with oil sump suction from the bottom.
2 smaller gear pumps (one each turbo)
Turbo timer 30 seconds.
Modified, cut an inch of oil pan.
« Reply #95 on: January 12, 2017 - 07:12:15 AM »
Spring 2016
I could not stand the noise of the fuelpump (Aeromotive Eliminator)
Switch to the Dual Phantom pump in-Tank with new tank and sender (Tanks Ink)
« Reply #96 on: January 12, 2017 - 01:57:09 PM »
Towards Umea and Savar Motor for Tuning / Dyno Testing.
Still snow April 2016, mixed emotions.
« Reply #97 on: January 13, 2017 - 09:27:57 AM »
Dyno ended in broken engine.
Run No. 21 the first pull up to 6000rpm....something happened.
Ticking sound that later proved 4 pushrods broken.
https://www.youtube.com/watch?v=qw6CyNb1Qjc
« Reply #98 on: January 13, 2017 - 10:02:49 AM »
Engine disassembled and analyzed.
Geometry errors pushrod / rocker arms main fault
Camshaft gear /reluctor wheel have split up
Heads dismantled and tested, no errors.
Tiny little marks on the pistons,they seem ok
« Reply #99 on: January 13, 2017 - 02:44:53 PM »
Just break down and come back.
1set custom pushrods
1set Hughes rocker shaft stablizer clamps & rocker arm collars
1set High Performance lifters
1set custom pistons (Diamond Piston)
Assemble and try again :stomp:
« Reply #100 on: January 13, 2017 - 03:10:47 PM »
Dyno testing for boost and backpressure.
Visit my friend on his rolling road.
Examines unstable boost pressure.
https://www.youtube.com/watch?v=QtpkmhZM96k
Offline YellowThumper
  • I left the snow for this?
« Reply #101 on: January 18, 2017 - 06:18:51 PM »
Awsome for the update.
Sorry to hear/see the failure issue.
Fully expect some of the same issues in my TT treck. Some day...
Best wishes you have the bugs handled and can go at and enjoy it longer.
« Reply #102 on: May 05, 2017 - 08:55:06 AM »
DYNO yesterday at Sävar Motor.
Stopped after the(Aeromotive dual phantom) fuel pumps did not deliver more.
Pumpgas1,3bar (18psi) 976RWHP 1361RWNM (1004 lb-ft)
https://www.youtube.com/watch?v=rK-GScGpAHM
Pumpgas0,8bar (11psi) 822RWHP 1088RWNM (802 lb-ft)
Pumpgas0,4bar (6psi) 668RWHP 900RWNM (664 lb-ft)
Offline soundcontrol
« Reply #103 on: May 06, 2017 - 02:59:29 PM »
Congrats. Amazing HP! Hope to see the car on some of the swedish meets this summer!
/ Ken
topic=108917.new#new
« Reply #104 on: May 07, 2017 - 10:18:53 PM »
 :bigsmile: WOW.
