Author Topic: Cuda Door Belt Molding Metal Clips  (Read 1755 times)
Offline crocha617
« on: September 29, 2014 - 03:09:28 PM »
Anyone have a couple of the metal clips that go on the ends of the belt moldings? The 71-74 fit I bought only came with the plastic parts.
Offline ShelbyDogg
Re: Cuda Door Belt Molding Metal Clips
« Reply #1 on: September 30, 2014 - 05:48:56 PM »
My kit came with all plastic clips too. Do you have a pic of the metal ones that you are looking for?
Offline crocha617
« Reply #2 on: September 30, 2014 - 07:19:18 PM »
Mine has studs across the top of the door that the plastic pieces clip to. The last spot towards the rear of the door has a hole for a metal bolt like clip. I have a picture at work. The think they are same as the vinyl top trim ones. I will try and post a pic tomorrow.
Offline anlauto
« Reply #3 on: September 30, 2014 - 07:25:17 PM »
The ones shown in this picture will work, it's what most kits include now, but they are not the same as originals.
You need to trim the stud after you tighten the nut :2cents:
Offline crocha617
« Reply #4 on: September 30, 2014 - 08:24:00 PM »
Yes those are the two metal ones I need.
Offline ShelbyDogg
« Reply #5 on: September 30, 2014 - 09:25:28 PM »
My '72 clips are all held on by welded studs too. Probably to stop the early rust issues caused by drilled holes like the front and rear windshields used. The metal ones in Alan's pic look like all of the trim hardware that was used on my '70 Challengers front hood and quarter and trunk's trim hardware.
Offline anlauto
« Reply #6 on: September 30, 2014 - 09:35:10 PM »
Should be available at any auto parts store. :2cents:
Offline crocha617
« Reply #7 on: October 01, 2014 - 07:06:51 AM »
Yeah I'm pretty sure I bought them at Napa years ago but I couldn't seem to find them online.  I will go in person this weekend and find something to work.
Offline crocha617
« Reply #8 on: October 02, 2014 - 07:24:46 AM »
After checking 3 auto parts stores last night on the way home I found them at Napa....Belt moldings are finally installed. Thanks Alan
