Author Topic: firewall insulation question  (Read 2142 times)
Offline shoooter
« on: September 30, 2014 - 06:28:14 PM »
I ordered a firewall insulation kit for a 71 cuda with air and it came with push christmas tree type fasteners do I use those or the firewall nails? I ordered both.
Also does anyone have a picture cause I can't seem to figure out how they all go. Does the piece behind the heater box get glued? Does the under dash insulation get glued aswell?.
Offline anlauto
Re: firewall insulation question
« Reply #1 on: September 30, 2014 - 06:41:40 PM »
Throw away the Christmas tree plugs and use the nails. For A/C I believe one piece does glue to the box itself and yes the upper dash insulation gets glued on. :2cents:
Offline dpcd67
« Reply #2 on: September 30, 2014 - 09:19:04 PM »
Under dash is glued; originally it was cheap blanket material. Firewall pad is a piece of cardboard with fiberglass like insulation glued to it and that is held on the firewall with the plastic pins. I used new sponge carpet pad glued to the top and dynamat on the firewall.  With an OEM type of cardboard pad on that, which was probably not necessary but I couldn't help it.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline shoooter
« Reply #3 on: October 01, 2014 - 11:37:32 AM »
I put sound deadened on the firewall Would you still use the firewall insulation?  Also what type of glue do you use?
Offline shoooter
« Reply #4 on: October 03, 2014 - 11:43:50 AM »
Also what type of glue do you use for weather stripping?
Offline roadman5312
« Reply #5 on: October 03, 2014 - 11:56:36 AM »
                 3M weatherstrip cement.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: October 03, 2014 - 12:55:14 PM »
I used the 3M 90 so you know down the road it will still have adhesion. The 77 will deteriorate over time.
Offline dpcd67
« Reply #7 on: October 04, 2014 - 12:03:10 PM »
For pad insulation I use 3M Spray adhesive (orange can), also for carpet. If you use Dynamat type stuff on the firewall then you don't need the cardboard/fiberglas piece too. But I put it on just in case.... It is quiet but the cardboard probably didn't help.  For weatherstripping I use 3M; I can't find the tube right now. But it is very strong stuff.
1963 Dodge M37 (3)
I ain't done yet.
