Author Topic: Mystery light issue for me  (Read 2061 times)
Offline Chlngrcrzy
« on: September 30, 2014 - 11:04:22 PM »
Front driver side valence(blinker) light will blink just fine when the headlights and parking lights are off. When you turn headlights or parking lights on, then it won't even light up or blink. Won't light up either when just parking lights are on. I have tried everything that i can think of. Any ideas?
Offline 1 Wild R/T
Re: Mystery light issue for me
« Reply #1 on: October 01, 2014 - 03:43:50 PM »
GROUND.........
Offline roadman5312
« Reply #2 on: October 01, 2014 - 03:51:55 PM »
GROUND.........
                                                               :iagree: check them all
Offline Chlngrcrzy
« Reply #3 on: October 02, 2014 - 08:54:15 PM »
Ok. I have scraped paint and made sure the housing is touching bare metal. Still doing it. What else can i ground?
Offline 71gogreen
« Reply #4 on: October 02, 2014 - 09:22:26 PM »
check socket-bulb-fuses :smokin: :thumbsup:
71challenger-millcreek park\71challenger-millcreek
Offline cuda346pk
« Reply #5 on: October 02, 2014 - 09:54:44 PM »
Try a temporary direct ground with a wire to the socket even using an alligator clip. Grounds can be so finicky.
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
Offline polarbear123
« Reply #6 on: October 03, 2014 - 08:50:12 AM »
How old is column switch?
Offline 1 Wild R/T
« Reply #7 on: October 03, 2014 - 02:15:33 PM »
It's clearly not the column switch....
Offline Chlngrcrzy
« Reply #8 on: October 03, 2014 - 11:06:34 PM »
I will give it a shot tomorrow. I was thinking about running a separate wire. I had to ground wire side lights on the back, to get them to work.
« Reply #9 on: October 06, 2014 - 09:19:50 AM »
Often the socket will lose contact with the housing, take a start punch & stake the socket where it meets the housing
Offline Chlngrcrzy
« Reply #10 on: October 06, 2014 - 10:22:13 PM »
On the inside or outside?
« Reply #11 on: October 06, 2014 - 11:12:19 PM »
Wherever you can , I usually stake it inside though
Offline Chlngrcrzy
« Reply #12 on: October 07, 2014 - 10:49:12 PM »
Solved.  I took a small punch and popped it once on the outside where the socket and housing come together. Light now works. Now if only all my other little electrical issues can be fixed that easy. Thanks Chryco
« Reply #13 on: October 08, 2014 - 09:41:44 PM »
 :2thumbs:
Offline CudamanTom
« Reply #14 on: October 08, 2014 - 10:02:59 PM »
I love a good ending.  :2thumbs: :bigsmile:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
