Firing order is right, I checked and rechecked it a few times. I pulled the rocker cover inspected the valve springs, didn't see anything, so I removed the rocker arms/shaft to get a better look at the valve springs, again didn't see/feel any cracks or damaged springs. with the rockers removed I was able to get 3 of the valve springs to shift/wiggle ever so slightly maybe 1/32-1/64th of an inch whereas the others didn't budge could this be part of the problem or am I just finding a problem where there is none
