Author Topic: K-Frame tolerances..... loose at best.  (Read 4205 times)
« on: October 02, 2014 - 02:44:45 PM »
Thought I'd share this....
So I'm thinking about what to do this winter, planning on a project with a couple of K-frames I have acquired. They are both supposed to be from an e-body?  So I thought I'd compare the two K-Frames I have.  I put the two side by side and started measuring. I found the mounting pad for the steering box varied by 2 degree's 21-23degrees, but the worst issue from a handling perspective was the locations of the steering box pad and the idler arm mount. It varied by up to 1/2" measured from the LCA pin holes. The LCA pin holes them selves were pretty close 1/8" at worst. The idler arms and pitman arm mounts NEED to be right if they are going to line up straight/parallel  when assembled. This could explain "some" of the header fitment issues as well as the nightmare fitment issues of the new Boregson steering box.  Again it could explain "SOME"  of the issues but not all.  Being a moldmaker and getting cranky when things are out by more than a thou this could make one OCD  :lol:  I assume it's just sloppy production tolerances from back in the day. Don't be too dismayed at Ma Mopar as from circle track racing I've also done measurements like this with Camaro front subframes , they varied 1" at times! ::)
Note the differences in steering box pad/gusset placement.
« Last Edit: October 02, 2014 - 02:51:57 PM by brads70 »
Offline anlauto
Re: K-Frame tolerances..... loose at best.
« Reply #1 on: October 02, 2014 - 02:48:27 PM »
There you go...over thinking it again Brad :nono: :smilielol:
Offline roadman5312
« Reply #2 on: October 02, 2014 - 03:18:58 PM »
    Thats really interesting Brad. We ran into issues on Toxicwolf's car where the center link wasn't parallel. Found a factory bulletin showing how to shim the steering box and/or file out the pitman arm holes oblong to correct the problem. I'm going to do some measurements on the hemi K based on your example here.  :2thumbs:
Offline 71gogreen
« Reply #3 on: October 02, 2014 - 03:24:37 PM »
Brad, I know what the problem is, you tape is worn out! :smokin: :icon16:
71challenger-millcreek park\71challenger-millcreek
Offline CudamanTom
« Reply #4 on: October 02, 2014 - 04:11:21 PM »
Will someone get Brad a beer please?  :smilielol:  :drunk:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline crash340
« Reply #5 on: October 02, 2014 - 05:03:20 PM »
Good stuff Brad, question is, does anyone have a factory engineering drawing on this to determine what it should be or is it best to just try and equal things up as best possible to the individual car etc.
Greg
Greg
73 Cuda
Brisbane, Australia
Offline ToxicWolf
« Reply #6 on: October 02, 2014 - 06:36:54 PM »
Offline GoodysGotaCuda
« Reply #7 on: October 02, 2014 - 06:42:53 PM »
Greg
x2
On top of all that you have to hope it's square in the car. Unfortunately almost nothing on these cars come even close to today's part variation standards.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #8 on: October 02, 2014 - 08:23:13 PM »
Yup. Very laughable . :lol:
« Reply #9 on: October 03, 2014 - 06:30:28 PM »
Sadly, this is the case with most of them. I think I have had to modify idler mounts and/or shim steering boxes to get the tie rod end locations correct on nearly every mopar I've ever had.
Offline Jesus H Chrysler
« Reply #10 on: October 04, 2014 - 12:06:44 PM »
One was made on Monday, and one on Friday?   :cheers: :drunk:  Thanks for pointing this out Brad.  I'll have to check my donor K before it goes in the Coronet.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline drewcrane
« Reply #11 on: October 04, 2014 - 01:39:51 PM »
They used the special stretch  fit technique,and an old jig ;)
« Reply #12 on: October 04, 2014 - 03:01:29 PM »
Trust me no jig was used.. a hand drawn blueprint  and a tape measure .What did you expect with 60s technology . Thats why its so funny.  :roflsmiley:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: October 04, 2014 - 04:06:48 PM »
I can see them swapping an engine drivetrain into another body because of these deltas.
I've been bit by the kmembervariances after using a buddys kmember so I would have to swap it out at the time.
Never again
