Fan Blade explosion.....Mopar carnage!
Author Topic: Fan Blade explosion.....Mopar carnage!  (Read 14501 times)
Offline 67vertman
  • Member since 9-23-2005
« on: October 04, 2014 - 12:19:19 PM »
If you are running a 40+ year old fan blade, check it closely and on a regular basis. Coming home from a cruise-in last night the fan blade on my 440 decided to “explode”.  No warning or signs that it was in distress.  :faint:
I am not sure why it let go, but it looks like one or more of the bolt holes must have developed a crack(s) and the rotational mass of the blades caused it to fly apart.  All the bolts are still attached to the fan clutch, and all the blades are attached as well, so it didn’t become unbalanced.
Damage is minimal (considering what could have happened) in my opinion, and consist of the following.
Aluminum Radiator (Griffith) $400
Battery $120
Battery ground cable $40
Fan blade and shroud $200, but I am now going with an electric fan, as I don’t want this to happen again.
Minor paint damage to the inside of the hood and air cleaner were the fan blades hit.
« Last Edit: October 04, 2014 - 01:03:45 PM by 67vertman »
Re: Fan Blade explosion.....Mopar carnage!
« Reply #1 on: October 04, 2014 - 12:47:58 PM »
Bummer! Clutch fan it looks like? Too bad we are not closer. I'm taking off my electric fan and triple pass aluminum rad to go with a bigger rad. I found the electric fans just don't provide enough airflow. That and the controller crapped out on me only running on slow speed then quit altogether. I had to wire the fan direct to the battery on the side of the road.  :pullinghair:
Offline 67vertman
« Reply #2 on: October 04, 2014 - 01:06:58 PM »
Brad, that's not good about the electric fan.  I need to do some research and I will talk with Griffith on Monday to what they recommend.  I didn't have any cooling issues with the original set up.
« Reply #3 on: October 04, 2014 - 02:06:52 PM »
I would insist on Spal or nothing. http://www.a1electric.com/catalog/cat_spal.htm
Basically I found the more amps the motor draws the better the fan. Low amp fans do not move air.  Then the next problem is your alternator capacity. It won't be enough! I killed my battery this summer driving to Carlisle ( 8 hour drive) I got about an hour and a half remaining and I had to get another battery on the road to finish the trip. I had a supposedly 95 amp alternator on there and it couldn't keep up. I rigged in a toggle switch to ground to make it home. I turned it off while on the hwy to charge the battery.
My suggestion after spending lots of money, I then bought one of these, http://www.qualitypowerauto.com/catalog.php?item=557
..... replace yours with a mechanical fan!
I bought this one because of the RPM rating. http://www.summitracing.com/int/parts/der-17018/overview/
They also make them to fit on your clutch set up,http://www.summitracing.com/int/parts/der-17118/overview/
 but if you go that route I'd suggest a new clutch, they are cheap enough. Here is the shorter Jag clutch if you need the extra 3/4" of clearance
http://www.summitracing.com/int/parts/hda-2765/applications
« Last Edit: October 04, 2014 - 02:09:51 PM by brads70 »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: October 04, 2014 - 04:11:59 PM »
No leakage from the rad after that explosion?
Think of it like lightning, won't strike twice in the same place. Especially witha new fan, electrics are a huge pain and I have found them to be unreliable on several cars.
B
Offline 67vertman
« Reply #5 on: October 04, 2014 - 06:34:52 PM »
I wish, the hole is BIG and all the fluid leaked out.  The motor didn't die right away as the small wire that grounds it to the body was enough to keep the car running.
« Reply #6 on: October 04, 2014 - 10:42:59 PM »
Research it before you commit to electric. Everybody that I know, including myself, went back to clutch fans after 'experimenting' with electric fans. :2cents:
Offline don340-4
« Reply #7 on: October 04, 2014 - 11:36:30 PM »
  Ron, is that fan one of those Mopar Performance fans that they claim uses less hp than the oem ones, I have had one on my Challenger for a few years now, maybe I should take a look at it. Thanks for the pictures, scary. Don
      :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Offline Gus cuda
« Reply #8 on: October 05, 2014 - 10:58:31 AM »
Wow! Reading this i cant help but think, what if you were under the hood tweaking something when this happend. That could be really bad.
Offline 1 Wild R/T
« Reply #9 on: October 05, 2014 - 11:36:22 AM »
      :wavingflag:
Looks like a seven blade fan which is OE the MP piece was five blades...
« Reply #10 on: October 05, 2014 - 11:49:07 AM »
I usea lot of the Flex a Lite 6 blade fans
« Reply #11 on: October 05, 2014 - 11:53:49 AM »
I think if you can adapt a factory electric fan/shroud, you'll have better luck. The aftermarket fans just don't seem to move enough air. I'm looking into a Ford Taurus fan/shroud for my 22" rad. A Ford Contour dual fan setup will fit a 26" rad.
Offline 67vertman
« Reply #12 on: October 05, 2014 - 01:14:24 PM »
      :wavingflag:
No, it was an OE 7 blade fan.  It looked good when I cleaned it up and painted it two years ago, no cracks in the bolt hole area.  I had it running at the cruise in, as someone wanted to hear it run and I had the hood open, I didn't notice a problem then and am glad it didn't explode then.
Offline 67vertman
« Reply #13 on: October 05, 2014 - 01:18:57 PM »
I have heard that the Mazda fans also work and cool well.
I am now leaning towards going with a mechanical fan and fan clutch, after hearing that the electric fans don't cool as well.
Offline 67vertman
« Reply #14 on: October 05, 2014 - 01:20:10 PM »
Does any company make a stock fan shroud for a 26 inch radiator?
