Dat's some cool chit right there. I might have to start browsing some of the used nascar parts stores for some of those.
With the divorced steering arm/bottom ball joint, you can alter length to speed up/slow down steering response or to restore ackerman for a front steer setup.
Heck, I'd leave the bolt pattern and have my S60 axles re-drilled for the 5 on 5 to use a wider selection of wheels, But I don't already have cool Minilites like you do.
They are hard to find from a road race car, most are from ovals and the spindles have different pin heights ,different KPI and steering arm lengths. And.... they usually weld the arm to the spindle. These were a nice score...free!
I thought it's pretty cool/ironic that they are real close to the 73 C-Body spindle even after all these years! Just beefier, slightly taller. When you factor in where the center of the lower ball joint is in relation to the pin/snout, they are real close.
I'm going to modify the steering arm to accept a screw in K719 ball joint from Howe (using these.
http://www.howeracing.com/p-7961-ball-joint-mounting-rings.aspx )as they have lots of pin height options to chose from and the K719 is the same pin taper as the standard k781/783 E-Body lower ball joints so I can use A-body LCA's like my last set up. . Also I can then put the ball joint where I want it height wise. I'm going to have to go to the bearing supply store in town to see if they make a smaller outer bearing OD wise but the same ID so I can make my hub snout a little smaller. Right now it's 3.050" and I think my rims are 3" minus the caps?
http://www.howeracing.com/p-7933-howe-22418-fits-k719.aspxI'm thinking about making my own K-Frame from square tubing and possibly a rack with front steer depending on what's in the way room wise? Then nice thing about making a K-Frame is I can adjust the LCA pin height where I want it and use the Speedway Engineering or Schroeder splined end sway bars.
http://www.schroedersteering.com/HomePage.html http://www.1speedway.com/index.htmNot rocket science and cheap to do material wise.
Woodward will make a rack in any width you request!
Center to center of the LCA pins is about 26 3/8 so a rack 2" shorter is what I figure I'll need.
http://www.woodwardsteering.com/images/rack%20and%20pinion%20units.pdfFailing that I'm hearing a Mustang rack is pretty close width wise too? 24"? Not sure about the steering ratio though? I can mess around with steering arm lengths to help with that too? I'll have to investigate that?
Brake options with 18" rims are wide open too! Rotor Diameter, thickness , Brake caliper options etc...
Lots of fun.....
