Author Topic: 1971 cuda 340/727 shaker coupe correct ring gear ratio?  (Read 743 times)
Offline culp71
« on: October 06, 2014 - 04:06:29 PM »
All,
I have a few question regarding rear end set up on a 1971 340/727 'cuda shaker coupe.
#1. What was the most common or the "correct" rear differential gear ratio used in a 1971 340/727 shaker cuda.
I see many gear ratio are avaible all the way down to 4:10's
so were all 340 paired with a certain ratio?
finding ratios ranged from 2.76 to 3.91. also some after market 4:10 's
seems most say 3.23:1-geared with the 8 3/4 axle automatic 727, and buyer had option to get 3.55 or 3.91:1 gears
#2 pinion size
1971 340/727 cuda shaker normally had which size?
did this correspond with gear ratio chosen?
The 1-3/8" 741 pinion,The 1-7/8" 489 or The 1-3/4" 742
thanks,
I just want to build it right, as it was and meant to be.
« Last Edit: October 07, 2014 - 03:42:48 PM by culp71 »
Offline anlauto
Re: 1971 340/727 shaker coupe correct ring gear ratio?
« Reply #1 on: October 06, 2014 - 05:11:54 PM »
3:23's in a 489 case. :2cents:
Offline culp71
« Reply #2 on: October 07, 2014 - 08:01:59 AM »
Ok, also with this engine/ trans/ shaker/ trim  combo were they all "sure-grip" equipped too?
Offline anlauto
« Reply #3 on: October 07, 2014 - 08:13:28 AM »
Nope...Sure Grip was an extra cost option, just like anything else.
