Author Topic: rallye wheel centre diam  (Read 1007 times)
Offline crash340
« on: October 08, 2014 - 05:34:34 PM »
Team, I'm considering buying a set of 14x6, rallye wheels and want to put the centers into wider rims with different bs. Question is could someone with both 14 and 15" rallye wheels advise if the center disc diameter are the same, ie will a 14" centre fit into a 15" rim?
Greg
73 Cuda
Brisbane, Australia
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: rallye wheel centre diam
« Reply #1 on: October 08, 2014 - 09:57:03 PM »
As long as they are both large bolt pattern they will fit. I assume you are looking at large bolt pattern wheels...
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline crash340
« Reply #2 on: October 08, 2014 - 11:44:34 PM »
yes they are both the large pattern but, I want to cut the centre disc out of the rim and re fit it to a larger width and possibly diam rim, i.e, use the dish/disc/center cut out of the 14" rim and weld it into a new wider 15" rim
Greg
73 Cuda
Brisbane, Australia
Offline Cudaragtop
« Reply #3 on: October 09, 2014 - 01:14:20 AM »
Misunderstood... Thought you just wanted to swap center caps... :clueless:
I had 14" ralleys before changing to Year One 17x8 front and 17x9 rear. Much better rubber available for 17s.
They have 72 style Acorn Centers available too.
The Firestone Indy 500 Wide Oval Ultra Performance Summer tires have great grip. They have a "W" Speed Rating to 168 MPH
275/40-17 next to a 245/60-14
- Randy D.
Offline crash340
« Reply #4 on: October 09, 2014 - 05:06:29 AM »
Still not quite there Cudaragtop sorry, if I have a set of 14" Rallye rims of my 73 Cuda for eg. I want to put them in a lathe and cut the weld that joins the centre disc to remove the 14" diam rim section, then buy a set of 15" rims that dont have any centres in them, then weld the centers from the 14" rims into the 15" rims, what I need someone to do is if they have both the factory 14" and 15" rims on hand, can they measure the centre diam to know if it it by chance is the same diam.
Greg
Greg
73 Cuda
Brisbane, Australia
Offline Priesty
« Reply #5 on: October 09, 2014 - 05:32:19 AM »
Just measured the centre plate width on my 15" rallies & it measures 31cm across. Can't help you with the 14" though.
cheers....
Steve.
Steve - 72  BS23  FY1  'Cuda.
Melbourne, Australia.
The term "Foolproof", seriously underestimates the ingenuity of fools.
CUDA Crop by steve, on Flickr
Offline crash340
« Reply #6 on: October 09, 2014 - 06:06:57 AM »
Thanks Mate, perfect, I have 14's so I can compare, currently thinking about getting a second set and putting them on say 15 x 9 rims until I can choose a set of mags
Greg
Greg
73 Cuda
Brisbane, Australia
Offline Priesty
« Reply #7 on: October 09, 2014 - 04:59:22 PM »
Will be interested to see how it works out, I think I have some 9" steel wheels here myself, might have to measure them up for same purpose.
Keep us posted.
Offline crash340
« Reply #8 on: October 12, 2014 - 06:24:11 PM »
It would look like the 14" centre is the same diameter, so it should be easy to cut out the centre of a set of 14"s and weld them into 15" rims, the width problem is realy on the trim ring, the wider you go the more the gap between the back edge of the trim ring to the centre disc as such
Greg
73 Cuda
Brisbane, Australia
