Author Topic: Woodgrain stickers  (Read 1240 times)
Offline CHL2T
  • Handle it, man!
Woodgrain stickers
« on: October 08, 2014 - 07:58:49 PM »
Hey guys, I am thinking of grabbing these http://www.ebay.com/itm/290903969203?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT    and was wondering what the best way to remove the fratzogs and then re attach them.....
Thanks!
Re: Woodgrain stickers
« Reply #1 on: October 08, 2014 - 10:34:57 PM »
I just filed of the backside 'peen' of the fratzog, and for reattaching, I put the fratzog back in place and dripped a couple drops of crazy glue from the backside to hold them in. Been two or three years now and they are still in place.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #2 on: October 09, 2014 - 12:51:20 AM »
I used the DMT woodgrain vinyl for the door inserts, as-well-as for the console plate; and they are excellent.  Regarding the door inserts:  I ground down the peened studs on the backside of the plate for the Fratzog, then applied the new vinyl, and then re-installed the Fratzog emblem, then applied some JB Weld.  After hardening, I ground down the the bead smooth, and all was good.  See photos.
« Last Edit: September 17, 2015 - 12:02:18 AM by filmsurgeon »
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline CHL2T
  • Handle it, man!
« Reply #3 on: October 09, 2014 - 12:54:34 PM »
I'm on it
Thanks Guys!
« Reply #4 on: October 09, 2014 - 01:15:21 PM »
Same thing here but I applied a very small amount of clear silicon to the pins with a took pick.  The silicone pushed out the sides in a couple places.(very very small amount)  Once it was completely dry, the excess came right off with a razor blade.
