Author Topic: Aluminum Dana 60  (Read 1175 times)
Offline arcticmopar
  • Yukon Canada
Aluminum Dana 60
« on: October 11, 2014 - 02:23:06 PM »
Has anyone else seen this article in Mcg ?
I fired off an email to the maker Baxtekmoto and they said its set up to accept the Mopar pinion snubber, is avail in any width,any brg type any gear, a TruTrac diff and Strange 35 spline axles for $3850.00 on asle for $3465.00. Any thoughts? I know Dr.Diff is the guy to go to and maybe he will add this to his line of products in the future. :dunno:
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Offline GoodysGotaCuda
Re: Aluminum Dana 60
« Reply #1 on: October 11, 2014 - 03:28:16 PM »
What's the weight savings?
Just an aluminum center or is the entire housing aluminum?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline arcticmopar
  • Yukon Canada
« Reply #2 on: October 11, 2014 - 03:47:42 PM »
Axle tubes are steel so just the center, forgot to ask about the wieght. :banghead: should be closer to a 8 3/4 but I will send anouther email and ask, will let you know.
Offline arcticmopar
  • Yukon Canada
« Reply #3 on: October 11, 2014 - 04:19:25 PM »
So just got a reply about wieght and its about 85lb less than a iron D60.
For a B-body width A60 with stock brg is 180lb vs stock D60 @ 265lb.
 Does that stock wieght seem correct for those that have one?
« Last Edit: October 11, 2014 - 04:21:16 PM by arcticmopar »
« Reply #4 on: October 11, 2014 - 07:20:15 PM »
From what I've heard gear sets don't last as long in aluminum carriers. Aluminum expands more than cast iron with temperature changes.  :dunno: :2cents:  Great weight savings though!  :2thumbs:
Offline arcticmopar
  • Yukon Canada
« Reply #5 on: October 14, 2014 - 03:37:12 PM »
Darn, good point there Brad, never thought of that. :dupe:
