Author Topic: larger discs  (Read 1097 times)
Offline gafletch
larger discs
« on: October 12, 2014 - 06:24:37 PM »
   If I go to larger manual front discs on the '70 Cuda, what setup is most reasonable?
Re: larger discs
« Reply #1 on: October 12, 2014 - 06:31:54 PM »
Using stock parts or aftermarket?
If stock parts are what you want this link is helpful
http://www.moparaction.com/Tech/archive/disc-main.html
Offline 67vertman
  • Member since 9-23-2005
Re: larger discs
« Reply #2 on: October 12, 2014 - 07:12:09 PM »
If you go any bigger, then what Bard showed you, you will need to go to larger rims.
I did the swap with stock components, they work great.
Offline cudazappa
Re: larger discs
« Reply #3 on: October 12, 2014 - 08:51:11 PM »
Cliff notes version: (assuming you have stock 70-72 disc setup now)
1) 77-81 B/R body Rotor (Cordoba, Magnum, St. Regis) & rear wheel bearing
2) Dr. Diff bearing spacer http://www.doctordiff.com/
3) 77-78 Caliper adapter (pin type)
Just hang up your calipers, remove your rotor and caliper adapter.  Install new caliper adapter.  Slide the bearing spacer on. Slide new rotor on.  Re-install your caliper.
One caveat, the rotors will require a 15" wheel!
I run this setup on my 71.  Plenty of brake for the car.
2015 Dart GT - Daily Driver
Offline HP_Cuda
  • Mopar or No Car!
Re: larger discs
« Reply #4 on: October 13, 2014 - 12:00:57 PM »
Dr Diff (cass) has some nice setups - check out his website.
B
