Author Topic: 727 noise in reverse  (Read 4905 times)
Offline don340-4
Re: 727 noise in reverse
« Reply #15 on: October 24, 2015 - 12:37:28 AM »
   ! Wild R/T, I think you may have figured out what is causing the noise, I have heard about the relief valve before, but no one has ever been able to explain it the way you did, it squeals in reverse & only for about 5 minutes after the first start of day, now can you tell me what I may be able to do to eliminate the noise, probably nothing to worry about but it is annoying.
        :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Offline 1 Wild R/T
« Reply #16 on: October 24, 2015 - 01:06:11 AM »
A cut & paste from the ATRA (Automatic Transmission Rebuilders of America) website....
Torqueflight
Buzz in reverse, worse cold. This problem cannot always be fixed. The customer is usually worried that something is seriously wrong and that he is going to have a breakdown that will cost him time and money. The way to handle the customer is to tell the plain and simple truth without blaming anyone else: "Sir, I do not know how to fix this noise." (Pause and wait for that to sink in.) "I do not know anybody who knows how to fix it. I assure you that it is oil noise and will not cause any future problem or expense." The key words here are, "I do not know how to fix it." Your customer will appreciate you honesty and probably find it very refreshing.
Now, let's fix the ones that we can and reduce the complaint on the rest:
1977 and later: The primary cause is the same as the C6 problem. Flat-sand the valve body and channel casting. The secondary cause is end clearance on pump gears. (Always flat-sand the 904 pump to fix shudder and vent leak). Swap 727 gears and pumps until you get a close clearance set.
Late 1968 to 1976: Just forget it. If you've got one that just has to get fixed, install later lockup valve body with the lockup disabled. Here is how to disable lockup or make a lockup body work on a non-lockup transmission: The pressure regulator spring retainer bracket angles toward the valve body and retains the switch valve spring. Use a pair of pliers to bend the angle toward the valve body until it collapses (compresses tight) the spring. The prevents the switch valve from opening by holding it inboard.
Offline don340-4
« Reply #17 on: October 24, 2015 - 01:24:33 AM »
 ! Wild R/T that is some solid information you posted, you guys on this board are just amazing, I might try that lockup valve body, I am not a transmission guy, but I will give it a try. Thank you.
Don
2012 Ram 1500 R/T
Offline crash340
« Reply #18 on: October 24, 2015 - 03:44:11 AM »
Good stuff,
Don, I backed my car out today after starting in P and the noise has pretty much good from what I can tell, the only thing I have going on now and since I put the shift kit in it is that when cold after sitting for a week or so when I start it in N is creeps forward a little, once warm its good
Greg
73 Cuda
Brisbane, Australia
Offline don340-4
« Reply #19 on: October 24, 2015 - 05:30:02 PM »
 Greg;
   I tried that too! the noise is still present, I think the best information we are going to get is from 1Wild R/T.
Don
2012 Ram 1500 R/T
Offline crash340
« Reply #20 on: October 24, 2015 - 06:52:06 PM »
I agree Don, PITA for you though
Greg
73 Cuda
Brisbane, Australia
