Author Topic: Source for Amp meter to Volt gauge conversion Cuda Rallye Dash  (Read 7619 times)
Offline austbrad
« on: October 14, 2014 - 08:23:56 AM »
Hi,
After a recent electrical meltdown, I've finally got my 71 Cuda running again, but the meltdown left me with some failed electrical parts and lots of blown bulbs. I had Crash340 come around over the weekend to help with the electrical diagnosis and repairs. Thanks again Greg.
We have bypassed the Amp gauge and eliminated the 16 and 18 bulkhead terminals. The voltage regulator feeding the small gauges failed. The tach and clock both failed.
What companies does everyone source their electrical parts from? I'm after the following parts.
1. Amp meter to Volt gauge conversion
2. Voltage regulator for gauge cluster
3. Quartz conversion for clock
4. Replacement internals for tachometer
5. Replacement road lamps switch
Thanks all.
Brad.
Offline Racer57
Re: Source for Amp meter to Volt gauge conversion Cuda Rallye Dash
« Reply #1 on: October 14, 2014 - 08:50:31 AM »
For the gauge conversions contact Redline.
http://www.redlinegaugeworks.com/default.asp
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #2 on: October 14, 2014 - 09:29:31 AM »
http://rt-eng.com/rte/index.php/RTE_limiter
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
« Reply #3 on: October 14, 2014 - 11:41:08 AM »
I got the R-3035 kit for the clock off ebay. So long as you are careful with the needles, it's a fairly easy straight forward 1 hr project.
http://www.ebay.com/sch/sis.html?_nkw=Quartz%20Conversion%20Clock%20Repair%20Kit%20R%203035%20Instructional%20DVD&_itemId=370726845673
I believe the tach inards can be bought from rt-eng as well.
Offline 1 Wild R/T
« Reply #4 on: October 15, 2014 - 02:20:23 AM »
If you care to convert your own Amp gauge to a volt gauge this is the recommended gauge for the conversion...
http://www.summitracing.com/parts/SUN-CP7985
Personally I highly recommend adding relays to your headlights, add a high blower relay & add a 8-10 gauge wire from the output terminal of the alternator to the battery post of the starter relay...
« Last Edit: October 15, 2014 - 02:23:26 AM by 1 Wild R/T »
Offline tman
« Reply #5 on: October 15, 2014 - 02:22:16 AM »
Is there a step by step to do the conversion from Amp to Voltage gauge?
Offline 1 Wild R/T
« Reply #6 on: October 15, 2014 - 02:28:40 AM »
I don't have a link but it's been discussed over on Moparts, the gauge is an easy change but most guys seem to just leave the ammeter face in place, when I get around to it I plan the print up a volt meter face with the correct font to look like it belongs... You need to attach the wires that bolt to the ammeter to each other & insulate them real well, The volt meter should be fed by a switched power connection...
Offline tman
« Reply #7 on: October 15, 2014 - 03:42:14 AM »
I like the idea of adding a wire from alternator output to battery post of the starter relay.  Is that just a single wire with eyelet terminals on either end?  Im more of a visual aid guy along with instruction.  I hear this method takes a lot of amps away from the amp gauge?  Does anything else need to be done if adding this wire?
Offline johannes
« Reply #8 on: October 15, 2014 - 11:52:41 AM »
Plenty of useful info here.  http://www.cuda-challenger.com/cc/index.php?topic=99741.msg1000844#msg1000844
I used orange nail paint on the new voltmeter needle...
As for the clock conversion....
Viping the clock with a damp cloth is NOT recomended.... risk of smudging white onto black.
If you can find tiny bolts instead of using rivets,... it will be easier.
Offline 1 Wild R/T
« Reply #9 on: October 16, 2014 - 12:08:09 AM »
That takes the charge load off the bulkhead connectors & the ammeter but now the ammeter will never show a charge so thats why you change to a voltmeter...
The headlight relays take another large load off the bulkhead connectors & the ammeter, plus suddenly the headlights are not only bright at idle but also considerably brighter when your driving...
The high blower relay does the same thing load wise & has the added benefit of suddenly your fan moves air volume comparable to a modern car... That problem has never been the fan motor or the design of the blower wheel/housing.. It's lack of current to run the motor properly...
Offline austbrad
« Reply #10 on: October 16, 2014 - 05:36:14 AM »
Hi Wild RT,
I like the sound of your headlight relay and blower relay. Do you have any diagrams or photos of your setup so I can see what you've done.
Thanks, Brad.
Offline 1 Wild R/T
« Reply #11 on: October 16, 2014 - 11:35:23 AM »
I have a headlight schematic, if you look in the current "Headlights" thread there is a link to a man that sells a high quality plug & play harness built specifically for your car....
On the blower relay I don't have a schematic but it's basically the same idea, I am supplying power  in the high blower position through a relay rather than the switch... Those switches are getting hard to replace & expensive & usually they have burnt high speed contacts...
Offline austbrad
« Reply #12 on: October 17, 2014 - 04:12:19 AM »
Thanks wild RT.
Offline crash340
« Reply #13 on: October 17, 2014 - 05:01:08 AM »
Easy enough to cut and splice into your existing circuit if you want, take a couple hours and done, I bought a new light harness and will prob just integrate the relays into it in thinking, probably put the relays on a plate under the battery
Greg
73 Cuda
Brisbane, Australia
Offline Katfish
  • 70 Challenger
« Reply #14 on: October 17, 2014 - 07:02:42 AM »
That's what I did, added a relay for the parking lights while at it
