Author Topic: 295's = snug fit ?  (Read 1289 times)
Offline leanburn
295's = snug fit ?
« on: October 15, 2014 - 09:31:22 PM »
i recently bought a new set of wheels, i got the tire shop to slap on a 295/45/18 to see how it fit and to my suprise its really close to being perfect. i have 3/4'' clearance at the leaf so i'm not worried there but i only have 1'' to the inner 1/4 panel [ lip has been rolled ] and the tire is 28.5'' tall so i'm worried that if i bottom the rear suspension the tire will rub the inner 1/4.
 is there anyone out there that is running a similiar size tire ? just curiuos if i'm gonna run into problems......... i really want to run these, if i go down a size there is only one brand of tire out there
Offline GoodysGotaCuda
Re: 295's = snug fit ?
« Reply #1 on: October 15, 2014 - 09:33:15 PM »
I run that size tire on my Barracuda and haven't had any issues. You may be able to get a HD ratchet strap to load your suspension and check your clearances.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline jhaag
« Reply #2 on: October 15, 2014 - 09:46:57 PM »
curious as to the combo? wheel offset/width, stock rear end, stock suspension cuda or Challenger? pictures? been thinking about running this size tire on my challenger
love 70 Challengers
« Reply #3 on: October 15, 2014 - 09:47:55 PM »
I'm running 295/40/18 with no issues.
« Reply #4 on: October 15, 2014 - 09:50:34 PM »
I run a 315/17 tire with no issues. The bottoming out thing is tough to accomplish actually. The rear is really light on these cars and as such, unless you are transporting a load of bricks in the trunk, you won't bottom out. :2cents:
Offline leanburn
« Reply #5 on: October 15, 2014 - 10:29:27 PM »
 hey goody, are you running a 295/45 or a 295,40?
if your running the 45 series would you be able to measure your clearance to 1/4 panel?
 the 40 series is a full inch shorter so it would be safer wich I may go that route but I would like to run the taller tire if possible
Offline leanburn
« Reply #6 on: October 15, 2014 - 10:31:33 PM »
ok, its a cuda, wheels are 18x8 with +6mm offset, stock rear, stock leafs
« Reply #7 on: October 15, 2014 - 11:17:05 PM »
I have some pics in the link in my sig. I think it's still there [on my phone]
My car is sort of apart, can't take any measurements at the moment!
1976 Dodge Warlock
