Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
1972 Barracuda vibrates when diving
« previous
next »
Print
Pages: [
1
Author
Topic: 1972 Barracuda vibrates when diving (Read 1053 times)
cmesa
Jr. Member
on:
October 21, 2014 - 09:03:56 PM »
Hello,
My car seems to vibrate when I drive, I changed the Ujoints and checked my rear axles but still have same problem.
Thank for any help provided.
Chris
Logged
GoodysGotaCuda
Sr. Resident
Re: 1972 Barracuda vibrates when diving
Reply #1 on:
October 21, 2014 - 09:22:35 PM »
Vibrates all of the time?
At speed?
During braking?
Certain speed?
Certain RPM?
Need some more info..
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
October 22, 2014 - 08:36:39 PM »
if you put the car in neutral when it is vibrating does it stop , this would eliminate the engine if it does
Logged
cmesa
Jr. Member
Reply #3 on:
October 22, 2014 - 08:56:21 PM »
Hello, it vibrates at all speeds, and when i put it in neutral it seems to not vibrate at all.
Thank you
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
October 22, 2014 - 09:33:28 PM »
then it would seem to be an engine issue , so what engine do you have , if it is a cast crank it needs special balancing , if it is a steel crank & has cast crank / offset balanced parts it will throw it off also
Logged
dfrazz
1970 Cuda - 1968 Charger
Resident
Reply #5 on:
October 22, 2014 - 09:42:54 PM »
Also check the flexplate (if automatic), engine externally balanced = external balanced flexplate (same for internal balanced engine=internal flexplate) and is it tight.
Logged
JayBee
Resident
Reply #6 on:
October 23, 2014 - 08:53:01 AM »
Here's yet another scenario I also had with my car once. Vibration while driving and went away when put in neutral. Mine turned out to be the output bearing in the tranny's tailshaft. Not saying this is your problem just relating my similar situation from years ago.
Logged
John
1970 Barracuda convertible
2014 Toyota Avalon
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
