Author Topic: Locate Mount/Brake  (Read 870 times)
Offline flagcraig
Locate Mount/Brake
« on: October 23, 2014 - 02:16:54 PM »
I can't seem to find this sway bar mount/braket from any of the suppliers.  Maybe I'm looking in the wrong place.  Any assistance is appreciated.
Offline crash340
Re: Locate Mount/Brake
« Reply #1 on: October 23, 2014 - 03:32:53 PM »
I dont believe you can buy it, there are aftermarket bolt on replacements but not like the factory unit you have, you can drill the two spot welds to break it apart, replace the bush and with care re weld the hoop back onto the base. I converted my factory unit to use the chassis bracket, welded a 1/4 plate to the front of it, drilled and tapped two 3/8 holes, screwed studs into them, welded them in place from the back then bolted the aftermarket hoop with Urethane bush onto the chassis bracket, works great. No additional holes in the chassis rail
Greg
73 Cuda
Brisbane, Australia
Offline JayBee
« Reply #2 on: October 24, 2014 - 09:49:49 AM »
I've got a pair without the rubber bushings. They need to be cleaned up and one of them needs some welding repair.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline flagcraig
« Reply #3 on: October 24, 2014 - 06:06:07 PM »
Unfortunately I'm not a welder guy.  Who might sell the aftermarket bolt ons?  Thanks.
If I can't find them then I will probably find a welder guy.
Thanks.
Offline crash340
« Reply #4 on: October 24, 2014 - 07:22:14 PM »
i got mine from the guys at Firm Feel
Greg
73 Cuda
Brisbane, Australia
Offline flagcraig
« Reply #5 on: October 28, 2014 - 05:00:06 PM »
Thanks for the lead (Firm Feel).  I called them and it looks like they have what I'm looking for.  And not a bad price.
