Author Topic: disc brake conversion photo's with factory adjustable tapered bearings  (Read 1139 times)
Offline crash340
Team,
Anyone have photo's of the disc brake caliper bracket for the R/H side that enables the use of the factory adjustable tapered bearings???? and or both sides with detail please.
Greg
Greg
73 Cuda
Brisbane, Australia
Re: disc brake conversion photo's with factory adjustable tapered bearings
« Reply #1 on: October 28, 2014 - 07:15:53 AM »
Not sure if this helps, but this is the Kit Cass supplied with my new Dana?
I machined the caliper myself for the oversize tapered bearings.
Offline crash340
« Reply #2 on: October 28, 2014 - 07:24:49 AM »
Thanks Brad, I was just looking at those photo's about an hour ago, was just wondering how he worked the adjuster on the R/H side of the 8 3/4. I can buy ford calipers and discs here with caliper bracket but may have to make a new bracket, if I lived over there I would just buy a kit from Cass but its just a little spendy by the time it gets here.
Greg
73 Cuda
Brisbane, Australia
Offline crash340
« Reply #3 on: November 03, 2014 - 02:35:21 PM »
So Brad, is that the non adjustable taper bearing, the set 20 version? and did Cass fit a pair of 3.15" bore hybrid housing ends?
Greg
73 Cuda
Brisbane, Australia
« Reply #4 on: November 03, 2014 - 04:07:21 PM »
Not sure what size they are? They were and upgrade and not adjustable. Yes the ends on the housing are special to suit the bearings.
Hope that helps?  :wave:
Offline crash340
« Reply #5 on: November 03, 2014 - 05:02:55 PM »
Yeah it does Brad, its what Cass was telling me as an option, right now its moving into a little to much work for all I'm chasing is a 1395mm housing just to fit the wheels I want under the car, I have an early C housing which is almost identical to an E body that I'll shorten, to keep the factory adjustable bearings, unless I move over to the green style bearings,there is a locally built ford Falcon that has a disc brake rear that is commonly used in conversions that I may look at, lots of stuff to think about, going to green bearings will eliminate a lot of housing shortening accuracy issues, not that I can't do it just options, who knows.
wish I lived in the US, would be a whole lot easier for sure
Greg
73 Cuda
Brisbane, Australia
