Author Topic: Shaker to hood rubber seal  (Read 3186 times)
Offline Racer57
« on: October 29, 2014 - 10:44:59 AM »
This is what mine looks like after I took off the duct tape. Should a good seals ends fit closer together and is there something that's suppose to hold them together ?
Offline 4Cruizn
  • HEMI FISH
Re: Shaker to hood rubber seal
« Reply #1 on: October 29, 2014 - 11:12:43 AM »
It comes as one piece . . . it appears that the seal where the two ends came together failed at one point and someone decided duct tape was the answer.   :dunno:
Offline 4 speed fish
« Reply #2 on: October 29, 2014 - 12:03:50 PM »
A friend of mine came up with a fix after I cut my seal a little short.Get a piece of rubber hose,insert the hose after gluing it into the open slot of the seal.Then glue the remaining edges and  secure with a big binder clip.Use 2 clips 1 where the hose is and the other where you join the seal.Use blue tape on the seal when you put the glue on so you don't get glue all over.
Offline 1 Wild R/T
« Reply #3 on: October 30, 2014 - 01:02:57 AM »
I think black duct tape was original... I saw plenty of cars with it back in the mid 70's...  A12 cars, T/A's & AAR's & Shaker cars.. All had a taped seam on the seal... And when you bought a new seal through Chrysler it wasn't one piece, it was supplied long & you cut it to fit...
« Last Edit: October 30, 2014 - 01:04:56 AM by 1 Wild R/T »
Offline 72ls5fla
« Reply #4 on: November 19, 2014 - 03:51:27 PM »
my very original 22500 mile shaker car has the tape too.
the ends are glued together with 3M weatherstrip glue.
Offline 73plymouth
« Reply #5 on: November 19, 2014 - 08:48:06 PM »
« Last Edit: November 19, 2014 - 08:50:32 PM by 73plymouth »
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #6 on: November 19, 2014 - 11:54:13 PM »
I bought a seal for my 6 barrel base from this guy recommended from Dave at Roseville.  The seal is perfect 1 thick piece.
www.shakerhood.com/products.php?id=ShakerComponents
Offline schtick
« Reply #7 on: November 25, 2014 - 07:25:15 PM »
I have the same one. This is how I made sure it would stay on the base after gluing.
Offline schtick
« Reply #8 on: November 25, 2014 - 07:27:14 PM »
Offline Racer57
« Reply #9 on: January 25, 2015 - 10:06:13 AM »
I ordered this from Dales Cuda.........   http://www.dalescudashop.com/19eshse.html
But I got one that has ends. Did they send the wrong one or is the pic misleading ?
Offline CudamanTom
« Reply #10 on: January 25, 2015 - 10:23:48 AM »
Sounds like you got one that separated at the seam. It should look like the pic on that link you provided.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
