Author Topic: 18" to 26" radiator install  (Read 3873 times)
Offline dave73chally
« on: November 02, 2014 - 04:52:55 PM »
Have a 73 challenger with an original 18" radiator. Replacing with a champion 26" triple core (cc2375).
Here's what I'm looking to buy:
http://m.ebay.com/itm/271649916163?nav=SEARCH
Will this bolt right in? What do I need for the install (other than new hoses)? Anyone have a source for the rubber mounts?
73 Challenger
Offline roadman5312
Re: 18" to 26" radiator install
« Reply #1 on: November 02, 2014 - 05:06:04 PM »
Rubber mounts  :clueless:
Offline anlauto
« Reply #2 on: November 02, 2014 - 05:23:29 PM »
You would need a 26" rad support to bolt it into.
Offline Pimtao
« Reply #3 on: November 02, 2014 - 05:46:51 PM »
So let's say I would buy an aftermarket rad support from amd to upgrade to a 26" rad how would I know the right sizes of the rad support the seem to come only in one size  :dunno: I always thought rads just interchange...
Offline Katfish
  • 70 Challenger
« Reply #4 on: November 02, 2014 - 05:56:48 PM »
Left side bolts in, drill new holes in right side.  You can trim the opening if you want, I didn't.
« Reply #5 on: November 02, 2014 - 05:59:22 PM »
I read some users used some sort of rubber bushing when installing, I think brads70 did he if sees this to chime in
73 Challenger
Offline ToxicWolf
« Reply #6 on: November 02, 2014 - 06:04:34 PM »
Someone will know the real answer but from electrical work I know that when copper and aluminium are connected we had to use special connectors to keep them from reacting with each other.  I suspect it is something like that.   :clueless:
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: November 02, 2014 - 08:31:39 PM »
Provides a little flex so the radiator won't get cracking if the support torques a little
« Reply #8 on: November 03, 2014 - 10:16:58 AM »
all aluminum rads are contained on rubber mount systems from the factory  as alum will not put up with flexing so I would recommned isolating the rad using rubber somehow , mounting direct to the firewall the rad may not last very long
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: November 03, 2014 - 02:15:33 PM »
you know there is a member here that sells those rads... :2thumbs:
IF you want it to look right, I agree
Jason
74 'cuda 360/727
Just call me a gearhead!
« Reply #10 on: November 03, 2014 - 03:23:48 PM »
Is ChallengerGary the member who sells these?
Also, in terms of a new rad support, it looks like AMD only sells one (AMD 350-1570-S) and it does not specify the radiator size opening. Are they all 26"?
73 Challenger
Offline anlauto
« Reply #11 on: November 03, 2014 - 03:49:04 PM »
YES
« Reply #12 on: November 03, 2014 - 04:41:49 PM »
I used an Allstar rad in mine , aluminum, common circle track rad, cheap to. I used well nuts to mount it in to absorb vibrations. Similar to Katfish's picture. Lowes stocks them in various sizes.
Offline Pimtao
« Reply #13 on: November 03, 2014 - 05:50:54 PM »
http://www.restorationradiators.com/products.asp?cat=1
Is that's the same guy? I was thinking getting the 26"small block.
Offline ToxicWolf
« Reply #14 on: November 03, 2014 - 09:58:01 PM »
I just ordered a 26 inch from him.   :bigsmile:
