Author Topic: 833 operating levers  (Read 687 times)
Offline Sleepychallenger
« on: November 03, 2014 - 12:21:11 PM »
Can anyone tell me what the numbers are on the operating levers? Looking at the pictures on brewers, I may have the wrong ones on there. I wonder if that is what is causing my 1-2 shifting issues. Im thinking that or the side cover 1-2 shift lever.
http://brewersperformance.com/proddetail.asp?prod=GL542U
http://brewersperformance.com/proddetail.asp?prod=OL-E
Offline 73EStroker
Re: 833 operating levers
« Reply #1 on: November 07, 2014 - 02:07:46 PM »
Those levers looked like what my 4 speed had. Don't know about the shift lever though. Now of course I have the Passon A855 and they are totally different. Sometimes (because these original transmissions are old) shifting issues are caused by worn parts inside the tranny such as 1-2 or 3-4 synchromesh hub that fits between (eg) 1st and 2nd gears. The outer shifting piece forms wear grooves in them and causes the sliding function to be dificult. When one takes a tranny apart anything that has grooves worn in should be replaced even though they cost lots but it gives the tranny a new lease on life.  In my opinion, I believe most tanny issues are not the levers and linkages outside but are worn parts and bearings on the inside. I base this last statement on all the gearboxes I have had issues with and how I repaired them and the end result.
Barry (Salmon Arm)
