Author Topic: Removing side glass and e-brake?  (Read 1303 times)
Offline carcrazyguy
« on: November 03, 2014 - 08:41:40 PM »
Okay to continue my "before it goes to the body shop". Lol
I need to remove the side glass (door and quarter).  The car will be media blasted so everything has to come out.  How do I tackle the glass?  Looking it over it appears that I would need to remove the glass before the tracks come out?  Or is there a way to pull the entire assembly as one?
The E-brake cable.  I have the entire pedal loose inside the car. The cable goes through the firewall, passes into the drivers front wheel area and back through the frame rails on the drivers side.  What holds the cable in the crossmember rail?  It feels like it just goes through the frame rail and angles to the crossmember rail.  I don't see a clip or anything. But it is not moving at all?
« Last Edit: November 03, 2014 - 08:58:10 PM by carcrazyguy »
Offline whitewatersky
Re: Removing side glass and e-brake?
« Reply #1 on: November 03, 2014 - 09:08:20 PM »
I'd post some pics but they're not on the phone
Plum Crazy auto T/A Challenger
Offline carcrazyguy
« Reply #2 on: November 03, 2014 - 10:55:50 PM »
Just let me know if you would rather email me...... :popcorn:
« Reply #3 on: November 04, 2014 - 07:04:00 AM »
disconnect the regulator first then loosen the tracks , the rear of the glass just hooks over the rear track , you have to remove the felt supports near the top of the door & the outer trim , rubber seal  , the regulator can be removed from the opening in the interior panel of the door , once the glass is free it can be slid out of the top of the door .
 The brake cable has a small barrel clip to lock it into the crossmember , carefulle squeeze the tabs while pushing back & it wil release
Offline carcrazyguy
« Reply #4 on: November 04, 2014 - 08:39:46 AM »
Thanks for the info! :2thumbs:  We are planning to tackle it tonight!
I guess the heavy undercoating is still hiding the barrel clip on the e-brake cable.  It did a great job protecting the floors and an even better job of being a pain the .....! :lol:
Offline carcrazyguy
« Reply #5 on: November 04, 2014 - 11:37:02 PM »
Success  :2thumbs:
Offline carcrazyguy
« Reply #6 on: November 04, 2014 - 11:38:23 PM »
Now the key will be trying to figure out how to get this jig saw puzzle back together in a few months. :22yikes:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #7 on: November 05, 2014 - 09:09:10 AM »
Lots of pictures!!   :picture: :picture: :picture:
« Reply #8 on: November 08, 2014 - 03:14:39 AM »
Sorry man. I been outta town since Tuesday. Back at work on Monday where te pics are kept...
