Well more pain ensues, I went over to the machine shop to check on my engine progress. I ended up milling the heads .030 to get the compression ratio correct but with the indy rockers I am having fitment issues with the push rods. they are cut to fit but if you get the rocker where you have some adjustment in the length I am going to have to open the passages up more because they are rubbing. Also didn't notice this before but the pushrods are .060 think tube. Should I step up to .080? everything for the heads was provided by indy, but I won't call them again and get treated like a dumb@$$.
