Author Topic: Home E-body Resto mod  (Read 65954 times)
Offline YellowThumper
  • I left the snow for this?
Re: Home E-body Resto mod
« Reply #165 on: April 26, 2016 - 11:03:48 PM »
 :cooldancing:
Offline EbodyMod
  • Will it ever be finished????
« Reply #166 on: April 27, 2016 - 07:38:03 AM »
yes, i used acetone to reduce it. i was nervous as heck but it worked out great
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline 70chall440
« Reply #167 on: April 27, 2016 - 11:57:03 AM »
very cool, now I just have to figure out what 10% represents and I will be good.. math was never my strong suit, thank god for the internet...  :bigsmile:
Current Mopar
Past Mopars
Offline EbodyMod
« Reply #168 on: April 27, 2016 - 03:36:04 PM »
i used eastwoods conutour poly primer, kit comes with a gallon of primer and 2 bottles of hardener. i marked the hardener bottles into 4 equal parts. one measured amount to 16 ounces of primer. for 16 ounces of primer I used about 1.5 oz of acetone.  they recommend only mixing 16ozs at a time but i used 32ozs per coat. 32ozs primer 1/2 bottle of hardener 3.5 ozs acetone.
Offline EbodyMod
« Reply #169 on: April 27, 2016 - 03:39:16 PM »
I will say i am tired of sanding but this stuff is sweet. Sands slick and smooth like a talcum powder. i quickly discovered i can skip straight to 320 grit to get going.  i am probably going to end around 1000 (320, 400, 600, 800, 1000) but i will see how it goes. :working:
Offline 70chall440
« Reply #170 on: April 27, 2016 - 03:43:36 PM »
Be careful how fine you go, you will need some mechanical bite for the paint. Most I have seen say 800 is as fine as you should go if you are shooting metallic. For solids, 320 is probably good enough, but you could go as fine as 600.
Current Mopar
Past Mopars
Offline EbodyMod
« Reply #171 on: April 27, 2016 - 03:56:13 PM »
the paint has metallics of several colors and 4 different pearls, the manufacturer recommends a MINIMUM 600. AKA sore sanding arms for a week
Offline 70chall440
« Reply #172 on: April 27, 2016 - 04:22:07 PM »
And there you have it...  :bigsmile: You know what is before you, have fun... I still cannot spray as the temps are sub 60 deg, hopefully this weekend.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #173 on: April 27, 2016 - 04:23:31 PM »
Awesome information, thanks.
Current Mopar
Past Mopars
Offline EbodyMod
« Reply #174 on: May 08, 2016 - 08:42:56 PM »
Well l had a bump in the road, had to go up north and see my dad. He is not doing so well again. but just got back to VA and time to start blocking again.    :working:
Offline 70chall440
« Reply #175 on: May 09, 2016 - 12:49:29 AM »
sorry to hear that, I hope he gets better.
I too have been blocking, go my 2K on and begun blocking that. I realized tonight that I actually mixed it with 1/2-3/4 the correct amount of hardner...  :banghead: So, I am going to block it out with 220, then shoot another coat (properly mixed this time), then do it again with 220 and then 320. Should get my paint this week, so with any luck at all, I should seal it and paint it this week.
Current Mopar
Past Mopars
Offline EbodyMod
« Reply #176 on: May 09, 2016 - 05:50:30 PM »
Well todays blocking session has come to an end. I am almost half way through, but it is readilly evident i will need at least one more go round with the poly primer.  All the (x)s are marking low spots.  :banghead:
Offline DAYLEY/CHALLENGER
« Reply #177 on: May 09, 2016 - 06:40:32 PM »
That's a lot of X,s.....rub on rub off....but this is more difficult.  Good lock.
Dave or David
Offline EbodyMod
« Reply #178 on: May 09, 2016 - 07:07:19 PM »
the good news is i haven't found anything that requires more than another coat or 2 of the poly primer. LOL
Offline 70chall440
« Reply #179 on: May 09, 2016 - 10:53:59 PM »
Man I know this effort... just shot the last of my 2K primer. Tomorrow, more block sanding...
Your car is looking good, keep at it and you will be rewarded.
Current Mopar
Past Mopars
