Author Topic: Home E-body Resto mod  (Read 65953 times)
Offline EbodyMod
  • Will it ever be finished????
Re: Home E-body Resto mod
« Reply #180 on: May 11, 2016 - 05:38:31 PM »
I just got a call from the machine shop, and good news for once. i got an adjustable lifter and pushrod from hughes engines to order custom thick wall push rods and when checking everything they discovered instead of the advertised .560 .565 lift with a 1.5 rocker.  i am at .586 and .600.  i hope that equals a few extra ponies!!!   :bigsmile:
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline 70chall440
« Reply #181 on: May 12, 2016 - 01:00:33 AM »
 :2thumbs:
Current Mopar
Past Mopars
Offline usraptr
« Reply #182 on: May 27, 2016 - 04:30:17 PM »
Good news on the cam!  :ylsuper:  I admire all your work on the primer and block sanding.   :ylsuper: To much work for me.  That's why so far I've had my best friend (paint and body man) do all my paint prep and painting but it looks like I may have to finish up some of the painting since he is always swamped now days.
(Edited 8-1-17)
Offline EbodyMod
« Reply #183 on: August 29, 2016 - 09:20:30 PM »
Hi guys, just got back from the desert. For those who have not been there the middle east is hotter than satan's a$$hol# right now but good to be home.  Went to the machine shop and all my engine pieces are back in the garage.   :bananasmi
Offline Cudakiller70
« Reply #184 on: August 30, 2016 - 02:20:51 AM »
Welcome back.  glad your back here safe. And I'm complaining about upper 90's.
The above is just my opinion
John Adams
Offline Challenger in NC
« Reply #185 on: August 31, 2016 - 03:08:08 PM »
Car looks great, far cry from where it started.
Offline EbodyMod
« Reply #186 on: September 01, 2016 - 07:02:40 AM »
 :hyper: :pullinghair: it is official, I must be "that guy" who has to buy every part twice.  I was installing the beautiful moly rings on my sweet custom pistons last night and I get to #8 piston and *snap*. I broke the dang lower compression ring. WTF??? Now I have to order a new set. I am hoping I can get just one ring but I have the sneaking suspicion I will be buying a whole set. Fingers crossed :banghead: :banghead: :banghead: :working:
Offline EbodyMod
« Reply #187 on: September 06, 2016 - 07:07:39 PM »
 :working: Well I got the new rings and the bottom end is together.  It is kinda nice all the little parts boxes are getting empty, the pile of parts is getting shorter! :woohoo:
Offline EbodyMod
« Reply #188 on: September 06, 2016 - 07:50:32 PM »
 :working: Here is some more pics.  Quick question??? i was just sitting the intake on top of the block to check clearances and noticed there are no guid pin hole on the new eddy RPM Air Gap.  Do you guys drill new hole on the intake or just pull the pins put of the block??? if you look at the last pic you will see what i am talking about
« Reply #189 on: September 06, 2016 - 08:36:18 PM »
I'd pull the pin ( pardon the pun.... :sly:) and put scribe makes on the edge of the ports on both the intake and the head so you can line up the ports.
Offline GoodysGotaCuda
« Reply #190 on: September 06, 2016 - 09:29:41 PM »
You'll need to pull the pins on both ends. I suggest a hearty bead of RTV to seal each end as well.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline EbodyMod
« Reply #191 on: September 11, 2016 - 09:02:11 AM »
Pin is pulled and waiting on my cometic head gaskets to arrive. i started mocking everything up and looking at fit. I noticed another small problem how are you guys running your heater hoses with the RPM Air gap manifold?? i see where in need to drill and put in the fitting for the water pump hose but the other heater hose does not have a good location and the one port that would work is on the wrong side of the intake.  Should i just re-route the hose or open up one of the holes on the passenger side of the manifold?
Offline vinb
« Reply #192 on: September 11, 2016 - 03:11:06 PM »
Looking at the photo of the cam plate, do you have the bolt with the oiling hole in it and the deflector plate to direct the oil for the timing chain??
Please check so you don't have any oiling issues.....
Vin.......
« Reply #193 on: September 11, 2016 - 03:34:47 PM »
My air gap is different? Did Edelbrock miss some steps my model # is 7576
« Last Edit: September 11, 2016 - 03:40:12 PM by Cudakiller70 »
John Adams
Offline EbodyMod
« Reply #194 on: September 11, 2016 - 05:22:13 PM »
with the intake i got mine from indy with the heads so they might have ordered them special without the hose allowance. :clueless:
as far as the cam plate no bolts have any hoes and i am not sure what you are talking about. i put it together the way it came apart
